AutoCAD And External Database Compatability
No aplicable
Hello, I have a mySql database that has a dataset I would like to graphically represent - hopefully with AutoCAD.
As a summary, I have a database field that has a flag. If the flag is 0, I would like to display a circle in a specific position. If it is 1, I would like to display a square.
Is this implementation/integration possible?
0 Me gusta
Responder
Soluciones aceptadas (2)
463 Vistas
2 Respuestas
Respuestas (2)
john.vellek
Solución aceptada
HI @Anonymous,
This kind of functionality is where AutoCAD Map is really great. In regular AutoCAD, database connectivity is possible.  Here is a link to a Tutorial on some of the functionality possible. This example uses Access but if you can create an ODBC connection then your database should work although I have tried Access myself.
Perhaps to get to your Circle zoom you can view the linked item as demonstrated. I hope this helps to get you started.
[EDIT}
I just realized this is AutoCAD for Mac. This functionality is not available on the Mac Platform. If running Windows-based AutoCAD in Bootcamp this should work fine though.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
maxim_k
Solución aceptada
Database connectivity is not available in AutoCAD for Mac. So you can accomplish your task only in AutoCAD for Windows.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
