I'm using AutoCAD 2023 (v2023.0.1) on Windows 10 21H2.
Our studio has mostly MacOS users, and I'm one of two Windows-based computers. Both Windows users are on the latest version of AutoCAD 2023. The MacOS users are on different versions of AutoCAD.
An issue we've just noticed as of yesterday was that when a drawing file is being opened by a WindowsOS user or a MacOS user, there will be no warning message stating the usual "DWG is currently in use or is read-only" error on either of these systems.
However on the same server, when Windows users open files opened by another Windows user the read-only pop-up message appears as it should. The same applies when MacOS users open drawings opened by other Mac users, the pop-up message also appears as it should.
In previous versions of AutoCAD, the read-only pop-up message would appear irrespective of which OS is opening the file on the server. So at this point, in our environment at least, it appears to be creating the above scenario between Windows and Mac computers.
This issue can be reproduced multiple times.
Any thoughts on this matter would be appreciated.
