AutoCAD 2020 LT for Mac - freezes after each command.
earthsquare
earthsquare
Hi.
I work on AutoCAD 2020 LT for Mac.
While working on a file, with and without external reference XRef, it freezes for a moment (lag of may be 2 seconds) after each command (like for eg fillet, offset etc). The cursor stops for two seconds and gets back to normal.
This disturbs the work flow.
Is anyone aware of the problem, if so please suggest a solution to this.
Regards
Sreejith.S
Landscape Architect
maxim_k
Hi Sreejith,
Remove all blocks from Recent Blocks tab of the Blocks palette (right-click and select "Clear all" from context menu).
Did this help?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
earthsquare
Dear Maxim.
It worked. Thanks.
Regards
Sreejith.S
Landscape Architect
I've been looking for this answer for months and it works! Thank you!
I hope everything good comes your way. This was killing. Thank you very very much!
filipefrancisco
@maxim_k wrote:
Hi Sreejith,
Did this help?
Great BUG??? Thanks for the solution
Filipe Francisco
Comunidade Autodesk - Português - Colaborador
Autodesk Certified Instructor | AutoCAD Certified | Revit Architecture Certified | Autodesk Expert Elite
YOUTUBE | LINKEDIN
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou.
If the answer solved your problem, click Accept as Solution. This helps other users to quickly find an answer. And hit Like if you do.
Autodesk Community
