Autocad 2019 would like to receive keystrokes from any application
when auto-cad is first launch we get the above questions the Jamf PPC utility does no have an option for input motioning. Is there a profile that will automatically give it access to what i needs? so this does not have to be done on every apple desktop?
running mac os 10.15.1
for some reason i cant run the update from the command line..
however it still install fine when ran from GUI.
when ran from the command line i get:
from install.log:
12-11 13:06:37-05 IT-imac-stu installd[841]: PackageKit: releasing backupd 2019-12-11 13:06:37-05 IT-imac-stu installd[841]: PackageKit: allow user idle system sleep 2019-12-11 13:06:37-05 IT-imac-stu installd[841]: PackageKit: Cleared responsibility for install from 948. 2019-12-11 13:06:37-05 IT-imac-stu installd[841]: PackageKit: Install Failed: Error Domain=PKInstallErrorDomain Code=112 "An error occurred while running scripts from the package “AutoCAD_Mac_2019.1_Update_Combo.pkg”." UserInfo={NSFilePath=./postinstall, NSURL=file:///Users/administrator/Desktop/Autodesk_2019-2020/AutoCAD_Mac_2019.1_Update_Combo.pkg#autocad2019.pkg, PKInstallPackageIdentifier=com.autodesk.autocad2019.P047.M.008.update, NSLocalizedDescription=An error occurred while running scripts from the package “AutoCAD_Mac_2019.1_Update_Combo.pkg”.} { NSFilePath = "./postinstall"; NSLocalizedDescription = "An error occurred while running scripts from the package \U201cAutoCAD_Mac_2019.1_Update_Combo.pkg\U201d."; NSURL = "file:///Users/administrator/Desktop/Autodesk_2019-2020/AutoCAD_Mac_2019.1_Update_Combo.pkg#autocad2019.pkg"; PKInstallPackageIdentifier = "com.autodesk.autocad2019.P047.M.008.update"; } 2019-12-11 13:06:37-05 IT-imac-stu installd[841]: PackageKit: Running idle tasks 2019-12-11 13:06:37-05 IT-imac-stu installer[948]: install:didFailWithError:Error Domain=PKInstallErrorDomain Code=112 "An error occurred while running scripts from the package “AutoCAD_Mac_2019.1_Update_Combo.pkg”." UserInfo={NSFilePath=./postinstall, NSURL=file:///Users/administrator/Desktop/Autodesk_2019-2020/AutoCAD_Mac_2019.1_Update_Combo.pkg#autocad2019.pkg, PKInstallPackageIdentifier=com.autodesk.autocad2019.P047.M.008.update, NSLocalizedDescription=An error occurred while running scripts from the package “AutoCAD_Mac_2019.1_Update_Combo.pkg”.} 2019-12-11 13:06:37-05 IT-imac-stu installd[841]: PackageKit: Removing client PKInstallDaemonClient pid=948, uid=0 (/usr/sbin/installer) 2019-12-11 13:06:37-05 IT-imac-stu installd[841]: PackageKit: Done with sandbox removals 2019-12-11 13:06:37-05 IT-imac-stu installer[948]: Install failed: The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.
terminal output:
administrator@IT-imac-stu ~ % administrator@IT-imac-stu ~ % sudo installer -pkg /Users/administrator/Desktop/Autodesk_2019-2020/AutoCAD_Mac_2019.1_Update_Combo.pkg -target /Applications iMac16,2 supported installer: Package name is Autodesk AutoCAD 2019.1 Update installer: Upgrading at base path / installer: The upgrade failed. (The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance. An error occurred while running scripts from the package “AutoCAD_Mac_2019.1_Update_Combo.pkg”.) administrator@IT-imac-stu ~ %
That is a clean install of auto desk, fresh machine with Catalina.
install autodesk from terminal - success
install autodesk update from terminal - failed
install autodesk update from GUI - success.
i received that alert on first launch of autodesk.
yes it will still launch
and yes i have done what it says, but we are an enterprise environment have have labs of computers touch each machine is not exactly ideal.
