Anuncios
AutoCAD 2016 for Mac won't open
No aplicable
My 2013 version of auto cad expired so I downloaded the 2016 version & it installed successfully but when I click on the app, it will bounce & try to load but then it will stop. I then downloaded the 2015 & 2014 version & they all did the same. I tried troubleshooting with the "FLEXnet" folder twice & still no luck. Any suggestions?
0 Me gusta
Responder
Soluciones aceptadas (2)
1.558 Vistas
16 Respuestas
Respuestas (16)
wispoxy
Just allow third party even though it's installed already, and try to reopen it.
Some applications are not signed by Apple and will not be able to be installed. If you trust the application and know you want to install it, follow these steps to allow third party apps to install.
  1. Open "System Preferences" by clicking on the Apple icon and choosing that option.
  2. Select "Security & Privacy" from the "System Preferences" window.
  3. Select the "General" tab, and select the lock in the lower left corner to allow changes.
  4. Enter your computer username and password, then select "Unlock."
  5. In the "Allow apps downloaded from:" section, select the radio button to the left of "Anywhere."
  6. Close the window. You can now install unsigned applications that you trust.
    • For security reasons, you may want to repeat this process checking "Mac App Store" on step five in order to turn this feature back off.
http://it.nmu.edu/docs/allowing-third-party-applications-install-macbook
0 Me gusta
wispoxy
Sounds like it's not seeing a valid source. Delete the desktop 'bouncy' icon. Go directly to the acad source, and replace back into quick access bar.
0 Me gusta
No aplicable
Deleting the bouncing icon doesn't work.
0 Me gusta
No aplicable
Changing the third party settings doesn't work.
0 Me gusta
maxim_k
Solución aceptada
I'd suggest you to try to use Clean Uninstall procedure:
https://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticle...
Than you can try to install 2016 version again.
BTW: AutoCAD for Mac signed by Apple.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
wispoxy
@maxim_k I couldn't even download and install AutoCAD 2015 or Maya without putting it on 'Anywhere' or typing in my password.
@Anonymous A clean install sounds good like @maxim_k mentioned. Re-download the installer, then re-install after completely removing all existing components.
0 Me gusta
maxim_k
@wispoxy
Here is Autodesk certificate:
I took screenshots from two installers.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
No aplicable
The clean uninstall seem to have worked some, but now I am getting an error message. I've attached a screenshot.
0 Me gusta
maxim_k
Now try to create new user account on your Mac, just for test. Login to this account and try to launch AutoCAD.
If it will launch, than there are permission problems in your main account.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Yes, it open and works on a guest profile. Thank you. How do I fix my permissions in my main account?
0 Me gusta
maxim_k
I'm afraid, I cannot help you, because repairing permissions is not a trivial task. I cannot guaranty you success without the possibility to be near your Mac. Sorry.
Maybe somebody from Autodesk staff will post here?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
I understand. The app just crashed on the guest account & now it won't reopen.
0 Me gusta
maxim_k
Solución aceptada
You can reset AutoCAD by holding down Shift key while clicking on the AutoCAD icon in the Dock. And if you are using Guest account you can log out and than login again - settings for all applications will be resented.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
No aplicable
Thank you. You've been of much help. Hopefully someone can help me with the permissions on my main account.
0 Me gusta
wispoxy
@maxim_k I agree with you, I just find it annoying we still have to type in our password. I'm going to verify the certificate as you showed in the image. Shared a kudos for your time, thanks for sharing.
0 Me gusta
No aplicable
The clean uninstall & the reseting of AutoCad seemed to do the trick. I can't thank you enough for your help.
0 Me gusta
