Anuncios
AutoCAD 2016 for Mac Update 4 is here: now it is compatible with Sierra
maxim_k
maxim_k
Just want to inform you:
AutoCAD 2016 for Mac (full and LT) Update 4 is ready for download and installation:
http://up.autodesk.com/2016/ACDMAC/AutoCAD2016Update4_Combo.dmg
http://download.autodesk.com/us/support/files/autocadlt_2016mac_update4/AutoCADLT2016Update4_Combo.d...
The Update 4 resolves the compatibility issues on macOS Sierra® and is recommended for all users.
Primary Issues Resolved by Update 4:
Sierra Compatibility
Crash when plot preview.
Image or PDF underlay shows as black box in printed result.
Viewport boundary not visible in printed result.
Stability
Crash when turn xref layer on/off.
Crash when switch layout/model tab.
Crash when open reference file in new window.
Performance
Improves the performance for saving files with large amount of annotation objects. Turning off the system variable "savefidelity" by default.
Text
Cannot disable the Autostacking option.
Hatch
Cannot recognize some custom hatch patterns.
Drafting
Cannot hold "shift" key to select multiple grips of Polyline for stretching.
Properties
The Properties palette does not show correct value for linetype property.
External Reference
Sometimes Xref with nested drawings cannot be loaded successfully.
Some image underlay does not show correctly after patching Update 3.
Nested image underlay does not show when inserted into another drawing as a block.
Insert
Fail to insert or copy/paste some drawing into the current one.
Viewport
Using trackpad should not be able to pan the view in a locked viewport.
The Update 4 is a combo update and can be patched on all official versions of AutoCAD 2016 for Mac.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Responder
1.949 Vistas
10 Respuestas
Respuestas (10)
No aplicable
This is a joke.  Sierra was launched in July for devs & been on my desktop since September.  What are Autodesk playing at, apart from taking a big wedge of cash off me each month?  I've installed update 4 & there seems to be a load of UI bugs relating to toolbar screen edge snap.
Even more annoying, the below hasn't been fixed:
https://forums.autodesk.com/t5/autocad-for-mac-forum/add-a-new-layout-in-an-existing-sheet-to-a-proj...
I have a company that writes software & my issue reported above should take no more than 2-3 man hours.
Not happy.
No aplicable
Just installed update 4.
Autocad crashes every time i make a change in a layout by right - clicking - > using the "edit page setup". when applying the changes, by pressing OK, the program crashes.
I am running sierra, and some of the drawings was created in acad 2015 mac.
When will this be fixed?
0 Me gusta
maxim_k
Welcome to Autodesk Forums!
Do you have printers / plotters installed on your system? Are they the same as you had when you was using 2015 version?
Do you have custom paper sizes in page Setups?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Hello Maxim,
The printers are the same, but I am working on a new computer, so the printers might not be named exactly the same.
I also have some custom paper sizes, but the problem occurs on printer standard paper sizes as A3 etc.
0 Me gusta
maxim_k
Have you tried to Reset Printing system on your Mac:
https://support.apple.com/kb/PH25565?viewlocale=en_US&locale=en_US
You can also try to delete all custom paper sizes on your Mac and than recreate them as needed.
After resetting Printing System (deleting all printers) - try to edit page setup in some of your drawings.
If AutoCAD will not crash - add printer(s) again one by one and check Page Setup editing in AutoCAD.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Hi Maxim,
I tried you suggestion, still no luck.
I removed all printers , rebooted the system, and then opened the drawing.
Opened a layout, chose edit page setup.
It showed me a dialogue saying "Printer ... cannot be found", i pressed OK.
Once into the page setup I changed the page size from A4 -> A3, pressed OK, and then acad crashes.
(The page was originally an A3)
0 Me gusta
maxim_k
Can you share your drawing here?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
maxim_k
Meanwhile, Can you create new user account on your Mac (just fot temporary test), than login to this new account and test AutoCAD behavior in it?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Hi Maxim,
I created a new user, signed in, and downloaded Autcad LT 2017 to try. the problem persists there as well. Even in an entirely blank drawing.
Program crashes after editing the page setup and pressing OK.
0 Me gusta
maxim_k
Personally I don't have any issues with Page Setup in AutoCAD 2016 and 2017 on Sierra, at the same time there are other users who reported about the issue you have.
Sorry, but at this point I have no idea how to resolve this issue. If the problem is on the System level, than fresh installation of OS could solve the problem, but I'm not sure...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
