Autocad 2016 for Mac doesn't print at all
Message 1 of 14
http://forums.autodesk.com/t5/autocad-for-mac-forum/why-is-my-autocad-for-mac-2016-with-update-4-fre...
I asked here and had some kindful help from @maxim_k, but didn't get the solution. My Autocad 2016 with Update 4 is not printing at all, and my 2015 prints with the black boxes you all know... Any help please?
Replies (13)
Message 2 of 14
maxim_k
Have you tried to reset AutoCAD?
Another way you can to try - create new user account on your Mac (it should not be guest account, but ordinary account, later you can delete it), login to it and test printing from this new account.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 14
By "reset" you mean restarting it? Because I did, I even restarted computer...
Or you mean reinstalling it?
Message 4 of 14
It prints sometimes, others doesn't... It's crazy. I've tried restarting, creating a new Page every time... And it works sometimes, others doesn't.
Message 5 of 14
maxim_k
By reset I mean resetting AutoCAD to default settings via menu AutoCAD -> Reset AutoCAD.
But if it prints sometimes, than I think the case is not in AutoCAD settings, but in the way how Layouts or Model space Setups are prepared.
If you are able to print from one of the Layouts one time: can you print from this Layout always?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 14
I print from Model, as I told you, but NO: with the same configuration, restarting or not... sometimes prints, sometimes it doesn't...
Message 7 of 14
maxim_k
Can you attach here the drawing you was able to print out successfully at least once?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 14
Sure, here it goes, with a couple of the images referenced in it
Message 9 of 14
maxim_k
Here is what I get with your file on my Mac:
Can you record screencast with the exact steps as in my screencast with the file you attached here?
What do you get?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 10 of 14
Message 11 of 14
maxim_k
I also noticed strange thing in page setup in the drawing you attached here: it is related to the printer you are using in page setup (Look on the bottom of the Page Setup Manager window).
Normally the Location parameter of the printer shows only one location, but in your case the location is doubled: Macbook Pro, Macbook Pro.
Can you try to remove this printer in macOS System Preferences and then add it again? Than use this newly added printer in page setup in AutoCAD.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 12 of 14
Ok, it works now EVERY TIME. It did four times in a row... I'm gonna cross my fingers and wait for a while, but it looks that finally you got the solution. Again, I love you!
Message 13 of 14
maxim_k
So the case was in incorrectly installed printer?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 14 of 14
It looks like that... Thanks a lot!!!
