Anuncios
Autocad 2015
Autocad 2015
No aplicable
I need help, I have AutoCAD 2015 on my mac and everytime I draw a line or a polyline, some little square show up with some type of fonction that I guess I can use. It seem to be practicle but it is actually more annoying than anything else. Is there any way I can remove that ?
My other problem is,, when I try to move a line or an object, everything that is connected to it will also move, even if I only selected the line or object I want to move. Same thing happen when I try to strech a line. Is there something I can do to avoid that to happen?
My AutoCAD also froze a lot, I don't have a lot of on my mac so I don't know what could cause the delays.
Thank you
0 Me gusta
Responder
333 Vistas
2 Respuestas
Respuestas (2)
maxim_k
Welcome to Autodesk Forums!
You have Infer Constraints enabled.
To turn this feature off-road look at the first button on the Status Bar to the right from "Model" and pick on it to turn Infer Constraints off.
Than use menu Parametric -> Delete Constraints item, type All, when AutoCAD asks to select objects and hit Return. This will delete all constraints in your drawing.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
No aplicable
Thank you for your answer.
0 Me gusta
