AutoCAD 2015 for Mac with OS X Yosemite CRASH!!!
This widget could not be displayed.
I used to have AutoCAD 2014 when I updated to the latest operating system (OS X Yosemite). However, it kept on crashing, and it was then when I found out that AutoCAD wasn't compatible with Yosemite yet. As a result, I decided to update to AutoCAD 2015 since it was compatible, but it seem to change anything since it keep on crashing. Is anyone experiencing the same issues?
Accepted solutions (3)
Replies (152)
Hi Maxim and others,
I was searching in this discussion for an answer but I seem to have an other problem than most people. My Acad'15 works en saves fine but when I open another file it crashes 7 out of 10 times. It also happens when I insert a block, insert reference, insert a PDF or insert an image. For opening new files I found a solution. When I select the file in Finder then Acad opens fine. But it should just work as it is meant to, and what to do with the other bugs?? Each day I spend +/- 45min. recovering my work so I really hope you could help me.
I already installed the Acad workaround.
Thanks!
Acad-2015
Macbook Pro Retina 15" medio 2014
OSx Yosemite
Intel Iris Pro 1536 MB
maxim_k
Hi jeroen,
Which view you have active in file operations dialog? If it is "column view":
try to switch it to list view:
and test if crashes will appear again.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
OdCStudio
Ah, he is lucky his AutoCAD actually opens.
My AutoCAD LT 2015 has COMPLETELY stopped responding.
Can you please advise on how to obtain a refund from Autodesk?
Thanks.
Hi Maxim,
So far so good! I haven't had a crash after I used the settings you suggested.
I really prefered the column setting. But hey, now I can continue my work and make money.
Thanks a lot!
OdCStudio
hi Maxim,
I've been trying with the reset option you gave me the other day, pressing shift before and during the opening of AutoCAD LT 2015. Apparently, it doesn't work anymore.... I want to thank you personally for the efforts, but I have to say that it is an absolute shame that Autodesk sells a product so unstable and so full of problems. My machine meets all the system requeriments to run AutoCAD LT and still, I stopped working and nothing can seem to be effective in bringing the AutoCAD back.
OdCStudio
Again, stuck here with a program that doesn't start - doesn't work and NO answers.
Any chance that anyone who knows a bit about this could respond?
maxim_k
So it appears that resetting AutoCAD doesn't helps to restore it's functionality any more.
Could you post here the contents of System.log from Console application at the moment when you are trying to launch AutoCAD?
Have you also tried to create new user account on your Mac (just temporary account for testing purposes - you can delete this account later), login to it and launch AutoCAD from this new account?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
OdCStudio
Hi Maxim, to answer your two-fold question, first part here.....
This is what I get in system.log:
May 10 08:37:57 Orestes-del-Castillos-iMac kernel[0]: Previous sleep cause: 5
May 10 08:37:57 Orestes-del-Castillos-iMac kernel[0]: The USB device HubDevice (Port 1 of Hub at 0xfa000000) may have caused a wake by issuing a remote wakeup (2)
May 10 08:37:57 Orestes-del-Castillos-iMac kernel[0]: 4462.355983: setDISASSOC from ATH_INTERFACE_CLASS disconnectVap
May 10 08:37:57 Orestes-del-Castillos-iMac.local discoveryd[73]: Basic DNSResolver UDNSServer:: PowerState is DarkWake
May 10 08:37:57 Orestes-del-Castillos-iMac kernel[0]: AirPort: Link Down on en1. Reason 8 (Disassociated because station leaving).
May 10 08:37:57 Orestes-del-Castillos-iMac kernel[0]: enet_event_func - vendor 1, class 1, subclass 2, event code 12
May 10 08:37:57 Orestes-del-Castillos-iMac kernel[0]: en1: channel changed to 2
May 10 08:37:57 Orestes-del-Castillos-iMac kernel[0]: en1::IO80211Interface::postMessage bssid changed
May 10 08:37:57 Orestes-del-Castillos-iMac kernel[0]: 4462.393150: setDISASSOCIATE ****STA SYNC DISASSOC SUCCESS
May 10 08:37:57 Orestes-del-Castillos-iMac.local UserEventAgent[37]: Captive: CNPluginHandler en1: Inactive
May 10 08:37:57 Orestes-del-Castillos-iMac.local networkd[176]: +[NETLedBelly stopFastFail] Clearing ledbelly failure cache
May 10 08:37:57 Orestes-del-Castillos-iMac kernel[0]: enet_event_func - vendor 1, class 1, subclass 2, event code 13
May 10 08:37:57 Orestes-del-Castillos-iMac kernel[0]: The USB device BRCM2046 Hub (Port 1 of Hub at 0xfa100000) may have caused a wake by issuing a remote wakeup (3)
May 10 08:37:57 Orestes-del-Castillos-iMac kernel[0]: The USB device Bluetooth USB Host Controller (Port 1 of Hub at 0xfa110000) may have caused a wake by issuing a remote wakeup (3)
May 10 08:37:57 Orestes-del-Castillos-iMac kernel[0]: 4462.594426: performCountryCodeOperation: Not connected, scan in progress[0]
May 10 08:37:57 Orestes-del-Castillos-iMac kernel[0]: full wake promotion (reason 1) 242 ms
May 10 08:37:57 Orestes-del-Castillos-iMac.local watchdogd[195]: [watchdog_daemon] @( pm_callback) - ref=0x0 msg_type=0xe0000320 msg=0x0
May 10 08:37:57 Orestes-del-Castillos-iMac.local WindowServer[177]: CGXDisplayDidWakeNotification [4462858243698]: posting kCGSDisplayDidWake
May 10 08:37:57 Orestes-del-Castillos-iMac.local WindowServer[177]: handle_will_sleep_auth_and_shield_windows: NULL shield_window (lock state: 1)
May 10 08:37:57 Orestes-del-Castillos-iMac.local imagent[295]: <IMMacNotificationCenterManager: 0x7fcc9bf2c0b0>: notification observer: com.apple.FaceTime notification: __CFNotification 0x7fcc9bd591f0 {name = _NSDoNotDisturbDisabledNotification}
May 10 08:37:57 Orestes-del-Castillos-iMac.local identityservicesd[286]: <IMMacNotificationCenterManager: 0x7fc019732240>: notification observer: com.apple.iChat notification: __CFNotification 0x7fc019429f00 {name = _NSDoNotDisturbDisabledNotification}
May 10 08:37:57 Orestes-del-Castillos-iMac.local discoveryd[73]: Basic Warn DD_Warn: Corrupt NSEC RDATA size
May 10 08:38:05 Orestes-del-Castillos-iMac.local discoveryd[73]: Basic DNSResolver UDNSServer:: PowerState is FullWake
May 10 08:38:05 Orestes-del-Castillos-iMac.local com.apple.backupd-helper[66]: Attempt to use XPC with a MachService that has HideUntilCheckIn set. This will result in unpredictable behavior: com.apple.backupd.status.xpc
May 10 08:38:05 Orestes-del-Castillos-iMac.local discoveryd[73]: Basic WABServer NetResolverEvent no resolvers, resetting domains
May 10 08:38:05 Orestes-del-Castillos-iMac.local configd[48]: network changed: v4(en1-:192.168.1.84) DNS- Proxy-
May 10 08:38:05 Orestes-del-Castillos-iMac kernel[0]: en1: 802.11d country code set to 'US '.
May 10 08:38:05 Orestes-del-Castillos-iMac kernel[0]: en1: Supported channels 1 2 3 4 5 6 7 8 9 10 11 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140 149 153 157 161 165
May 10 08:38:05 Orestes-del-Castillos-iMac com.apple.xpc.launchd[1] (com.apple.bsd.dirhelper[5006]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.bsd.dirhelper
May 10 08:38:06 Orestes-del-Castillos-iMac kernel[0]: en1: channel changed to 1
May 10 08:38:13 --- last message repeated 1 time ---
May 10 08:38:06 Orestes-del-Castillos-iMac kernel[0]: en1: BSSID changed to a0:21:b7:af:bd:74
May 10 08:38:06 Orestes-del-Castillos-iMac kernel[0]: en1: channel changed to 2
May 10 08:38:06 Orestes-del-Castillos-iMac kernel[0]: en1::IO80211Interface::postMessage bssid changed
May 10 08:38:06 Orestes-del-Castillos-iMac kernel[0]: AirPort: Link Up on en1
May 10 08:38:06 Orestes-del-Castillos-iMac kernel[0]: 4471.613745: apple80211Request[10514] Unsupported ioctl 181
May 10 08:38:06 Orestes-del-Castillos-iMac kernel[0]: 4471.613752: apple80211Request[10514] Unsupported ioctl 181
May 10 08:38:06 Orestes-del-Castillos-iMac kernel[0]: enet_event_func - vendor 1, class 1, subclass 2, event code 13
May 10 08:38:06 Orestes-del-Castillos-iMac kernel[0]: AirPort: RSN handshake complete on en1
May 10 08:38:06 Orestes-del-Castillos-iMac kernel[0]: PM response took 1286 ms (49, powerd)
May 10 08:38:06 Orestes-del-Castillos-iMac.local watchdogd[195]: [watchdog_daemon] @( pm_callback) - ref=0x0 msg_type=0xe0000300 msg=0x0
May 10 08:38:06 Orestes-del-Castillos-iMac.local coreaudiod[313]: 2015-05-10 08:38:06.516784 AM [AirPlay] Power: SystemHasPoweredOn
May 10 08:38:06 Orestes-del-Castillos-iMac.local coreaudiod[313]: 2015-05-10 08:38:06.516895 AM [AirPlay] BTLE client starting to browse for AirPlay Solo Target Presence.
May 10 08:38:06 Orestes-del-Castillos-iMac.local blued[82]: Acquiring the wifi lock
May 10 08:38:06 Orestes-del-Castillos-iMac.local coreaudiod[313]: 2015-05-10 08:38:06.517418 AM [AirPlay] BTLE client stopping to browse for AirPlay Solo Target Presence.
May 10 08:38:06 Orestes-del-Castillos-iMac.local coreaudiod[313]: 2015-05-10 08:38:06.517552 AM [AirPlay] BTLE client starting to browse for AirPlay Solo Target Presence.
May 10 08:38:06 Orestes-del-Castillos-iMac.local coreaudiod[313]: 2015-05-10 08:38:06.517736 AM [AirPlay] BTLE client started to browse for AirPlay Solo Target Presence.
May 10 08:38:06 Orestes-del-Castillos-iMac.local coreaudiod[313]: 2015-05-10 08:38:06.518176 AM [AirPlay] BTLE client stopped to browse for AirPlay Solo Target Presence.
May 10 08:38:06 Orestes-del-Castillos-iMac.local coreaudiod[313]: 2015-05-10 08:38:06.518391 AM [AirPlay] BTLE client started to browse for AirPlay Solo Target Presence.
May 10 08:38:06 Orestes-del-Castillos-iMac.local networkd[176]: +[NETLedBelly stopFastFail] Clearing ledbelly failure cache
May 10 08:38:06 Orestes-del-Castillos-iMac.local UserEventAgent[37]: Captive: [CNInfoNetworkActive:1709] en1: SSID 'ORESTES'HOME' making interface primary (cache indicates network not captive)
May 10 08:38:06 Orestes-del-Castillos-iMac.local configd[48]: network changed: DNS* Proxy
May 10 08:38:06 Orestes-del-Castillos-iMac.local UserEventAgent[37]: Captive: CNPluginHandler en1: Evaluating
May 10 08:38:06 Orestes-del-Castillos-iMac.local UserEventAgent[37]: Captive: en1: Not probing 'ORESTES'HOME' (cache indicates not captive)
May 10 08:38:06 Orestes-del-Castillos-iMac.local UserEventAgent[37]: Captive: CNPluginHandler en1: Authenticated
May 10 08:38:06 Orestes-del-Castillos-iMac.local imagent[295]: <IMMacNotificationCenterManager: 0x7fcc9bf2c0b0>: NC Disabled: NO
May 10 08:38:06 Orestes-del-Castillos-iMac.local identityservicesd[286]: <IMMacNotificationCenterManager: 0x7fc019732240>: NC Disabled: NO
May 10 08:38:06 Orestes-del-Castillos-iMac.local sharingd[292]: 08:38:06.868 : Starting AirDrop server for user 501 on wake
May 10 08:38:07 Orestes-del-Castillos-iMac.local configd[48]: network changed: v4(en1!:192.168.1.84) DNS+ Proxy+ SMB
May 10 08:38:07 Orestes-del-Castillos-iMac.local identityservicesd[286]: <IMMacNotificationCenterManager: 0x7fc019732240>: DND Enabled: NO
May 10 08:38:07 Orestes-del-Castillos-iMac.local imagent[295]: <IMMacNotificationCenterManager: 0x7fcc9bf2c0b0>: DND Enabled: NO
May 10 08:38:07 Orestes-del-Castillos-iMac.local imagent[295]: <IMMacNotificationCenterManager: 0x7fcc9bf2c0b0>: Updating enabled: YES (Topics: (
"com.apple.ess",
"com.apple.private.ac"
May 10 08:38:07 Orestes-del-Castillos-iMac.local identityservicesd[286]: <IMMacNotificationCenterManager: 0x7fc019732240>: Updating enabled: YES (Topics: (
"com.apple.private.alloy.icloudpairing",
"com.apple.private.alloy.continuity.encryption",
"com.apple.private.alloy.continuity.activity",
"com.apple.private.alloy.idstransfers",
"com.apple.private.ids",
"com.apple.private.alloy.phonecontinuity",
"com.apple.ess",
"com.apple.madrid",
"com.apple.private.alloy.continuity.auth",
"com.apple.private.ac",
"com.apple.private.alloy.idsremoteurlconnection",
"com.apple.private.alloy.sms",
"com.apple.private.alloy.screensharing",
"com.apple.private.alloy.maps",
"com.apple.private.alloy.callhistorysync",
"com.apple.private.alloy.continuity.tethering"
May 10 08:38:07 Orestes-del-Castillos-iMac.local identityservicesd[286]: <IMMacNotificationCenterManager: 0x7fc019420e00>: notification observer: com.apple.iChat notification: __CFNotification 0x7fc019752270 {name = _NSDoNotDisturbDisabledNotification}
May 10 08:38:07 Orestes-del-Castillos-iMac.local blued[82]: Acquired the wifi lock
May 10 08:38:07 Orestes-del-Castillos-iMac.local blued[82]: Release the WiFi lock
May 10 08:38:08 Orestes-del-Castillos-iMac.local identityservicesd[286]: <IMMacNotificationCenterManager: 0x7fc019420e00>: NC Disabled: NO
May 10 08:38:09 Orestes-del-Castillos-iMac.local identityservicesd[286]: <IMMacNotificationCenterManager: 0x7fc019420e00>: DND Enabled: NO
May 10 08:38:09 Orestes-del-Castillos-iMac.local identityservicesd[286]: <IMMacNotificationCenterManager: 0x7fc019420e00>: Updating enabled: YES (Topics: (
"com.apple.madrid"
May 10 08:38:09 Orestes-del-Castillos-iMac.local ntpd[186]: wake time set +0.224790 s
May 10 08:38:09 Orestes-del-Castillos-iMac.local discoveryd[73]: Basic DNSResolver Return Code is 9 and we are treating it as an error!
May 10 08:38:10 Orestes-del-Castillos-iMac.local discoveryd[73]: Basic NATTServer Got device info URL: http://192.168.1.1:5555/rootDesc.xml
May 10 08:38:10 Orestes-del-Castillos-iMac.local discoveryd[73]: Basic NATTServer Got control URL: http://192.168.1.1:5555/ctl/IPConn (ip)
May 10 08:38:10 Orestes-del-Castillos-iMac kernel[0]: en1: BSSID changed to a0:21:b7:af:bd:74
May 10 08:38:10 Orestes-del-Castillos-iMac kernel[0]: en1: channel changed to 2
May 10 08:38:10 Orestes-del-Castillos-iMac.local discoveryd[73]: Basic DNSResolver Return Code is 9 and we are treating it as an error!
May 10 08:38:11 Orestes-del-Castillos-iMac com.apple.xpc.launchd[1] (com.autodesk.AutoCADLT2015_StandAlone.23320[3217]): Service exited due to signal: Killed: 9
May 10 08:38:12 Orestes-del-Castillos-iMac.local discoveryd[73]: Basic DNSResolver Return Code is 9 and we are treating it as an error!
May 10 08:38:19 --- last message repeated 5 times ---
May 10 08:38:12 Orestes-del-Castillos-iMac.local mapspushd[319]: 2015-05-10 08:38:12.343, 319, c0e10580, [MapsAnnouncements]: server returned error: 404 for URL http://gspe21.ls.apple.com/config/announcements?hardware=iMac11,3&lang=en&os=osx&os_build=14D136&os_...
May 10 08:38:12 Orestes-del-Castillos-iMac.local mapspushd[319]: 2015-05-10 08:38:12.344, 319, c0e10580, [MapsAnnouncements]: Failed to load announcements document: Error Domain=GEOErrorDomain Code=-601 "The operation couldn’t be completed. (GEOErrorDomain error -601.)" UserInfo=0x7fd8c0f195c0 {NSErrorFailingURLStringKey=http://gspe21.ls.apple.com/config/announcements?hardware=iMac11,3&lang=en&os=osx&os_build=14D136&os_... HTTP Status Code=404}
May 10 08:38:13 Orestes-del-Castillos-iMac.local nsurlstoraged[250]: realpath() returned NULL for /var/folders/zz/zyxvpxvq6csfxvn_n00000s0000068/C/com.apple.SoftwareUpdate
May 10 08:38:13 Orestes-del-Castillos-iMac.local nsurlstoraged[250]: The read-connection to the DB=/var/folders/zz/zyxvpxvq6csfxvn_n00000s0000068/C/com.apple.SoftwareUpdate/Cache.db is NOT valid. Unable to determine schema version.
May 10 08:38:20 --- last message repeated 1 time ---
May 10 08:38:13 Orestes-del-Castillos-iMac.local nsurlstoraged[250]: ERROR: unable to determine file-system usage for FS-backed cache at /var/folders/zz/zyxvpxvq6csfxvn_n00000s0000068/C/com.apple.SoftwareUpdate/fsCachedData. Errno=13
May 10 08:38:13 Orestes-del-Castillos-iMac.local CalendarAgent[246]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:13 Orestes-del-Castillos-iMac.local com.apple.iCloudHelper[1022]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:13 Orestes-del-Castillos-iMac.local apsd[74]: Illegal subject name missing 'courier.push.apple.com' (2.5.4.3): ({
label = "2.5.4.6";
"localized label" = "2.5.4.6";
type = string;
value = US;
label = "2.5.4.8";
"localized label" = "2.5.4.8";
type = string;
value = California;
label = "2.5.4.7";
"localized label" = "2.5.4.7";
type = string;
value = Cupertino;
label = "2.5.4.10";
"localized label" = "2.5.4.10";
type = string;
value = "Apple Inc.";
label = "2.5.4.3";
"localized label" = "2.5.4.3";
type = string;
value = "courier.sandbox.push.apple.com";
May 10 08:38:14 Orestes-del-Castillos-iMac.local CalendarAgent[246]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:14 Orestes-del-Castillos-iMac.local com.apple.iCloudHelper[1022]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:14 Orestes-del-Castillos-iMac com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
May 10 08:38:15 Orestes-del-Castillos-iMac.local locationd[79]: Location icon should now be in state 'Active'
May 10 08:38:15 Orestes-del-Castillos-iMac.local syncdefaultsd[5014]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
May 10 08:38:15 Orestes-del-Castillos-iMac.local discoveryd[73]: Basic DNSResolver Return Code is 9 and we are treating it as an error!
May 10 08:38:21 --- last message repeated 4 times ---
May 10 08:38:17 Orestes-del-Castillos-iMac.local com.apple.iCloudHelper[1022]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
May 10 08:38:17 Orestes-del-Castillos-iMac.local com.apple.iCloudHelper[1022]: AOSKit ERROR: Setup request failed, appleID=odcstudio, url=https://setup.icloud.com/setup/login_or_create_account, requestHeaders=
"Accept-Language" = "en-us";
Authorization = "...";
"X-APNS-Token" = ...;
"X-Aos-Accept-Tos" = false;
"X-Apple-MD" = "";
"X-Apple-MD-M" = "";
"X-Mme-Client-Info" = "<iMac11,3> <Mac OS X;10.10.3;14D136> <com.apple.AOSKit/217 (com.apple.CalendarAgent/8.0)>";
"X-Mme-Country" = US;
"X-Mme-Device-Id" = "B1368850-970D-5783-9E06-864DC418465B";
"X-Mme-Nas-Qualify" = "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";
"X-Mme-Timezone" = EDT;
error=Error Domain=AOSErrorDomain Code=1000 "The operation couldn’t be completed. (AOSErrorDomain error 1000.)" UserInfo=0x7ffe0a6020c0 {HttpStatusCode=401, DialogInfo={
"AlternateButtonLabel.skipped" = "";
"AlternateButtonLink.skipped" = "";
Body = "If you have an iCloud account, sign in using your iCloud email address.";
DefaultButtonLabel = OK;
"DefaultButtonLink.skipped" = "";
DialogType = GenericDialog;
ErrorID = "NON_EMAIL_FAILED_AUTH";
Header = "An Apple ID that is an email address is required to use iCloud.";
"HelpLink.skipped" = "";
description = "Non-Email Apple ID Entered (Failed Auth)";
localizedError = "NON_EMAIL_FAILED_AUTH";
protocolVersion = 2;
}}, httpStatusCode=401, responseHeaders=
"Cache-Control" = "no-cache, no-store, private";
"Content-Encoding" = gzip;
"Content-Length" = 456;
"Content-Type" = "application/xml; charset=UTF-8";
Date = "Sun, 10 May 2015 12:38:17 GMT";
"X-Apple-Request-UUID" = "54760a93-9a7e-4065-82ff-1caa8dc226db";
"X-Responding-Instance" = "setupservice:10500401:st11p05me-setupsvc004:8001:15B64:170525";
responseBody=
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>protocolVersion</key>
<string>2</string>
<key>DefaultButtonLabel</key>
<string>OK</string>
<key>Body</key>
<string>If you have an iCloud account, sign in using your iCloud email address.</string>
<key>ErrorID</key>
<string>NON_EMAIL_FAILED_AUTH</string>
<key>DialogType</key>
<string>GenericDialog</string>
<key>AlternateButtonLink.skipped</key>
<string></string>
<key>AlternateButtonLabel.skipped</key>
<string></string>
<key>localizedError</key>
<key>DefaultButtonLink.skipped</key>
<string></string>
<key>Header</key>
<string>An Apple ID that is an email address is required to use iCloud.</string>
<key>description</key>
<string>Non-Email Apple ID Entered (Failed Auth)</string>
<key>HelpLink.skipped</key>
<string></string>
</dict>
</plist>
May 10 08:38:18 Orestes-del-Castillos-iMac.local CalendarAgent[246]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:18 Orestes-del-Castillos-iMac.local com.apple.iCloudHelper[1022]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:19 Orestes-del-Castillos-iMac.local locationd[79]: NETWORK: requery, 0, 0, 0, 0, 2, items, fQueryRetries, 0, fLastRetryTimestamp, 452894173.8
May 10 08:38:19 Orestes-del-Castillos-iMac.local CalendarAgent[246]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:20 Orestes-del-Castillos-iMac.local com.apple.iCloudHelper[1022]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:20 Orestes-del-Castillos-iMac.local CalendarAgent[246]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:21 Orestes-del-Castillos-iMac.local nbagent[5017]: XPC Activity invoked with state=0
May 10 08:38:21 Orestes-del-Castillos-iMac syslogd[38]: Configuration Notice:
ASL Module "com.apple.AccountPolicyHelper" claims selected messages.
Those messages may not appear in standard system log files or in the ASL database.
ASL Module "com.apple.authd" sharing output destination "/var/log/asl" with ASL Module "com.apple.asl".
Output parameters from ASL Module "com.apple.asl" override any specified in ASL Module "com.apple.authd".
ASL Module "com.apple.authd" sharing output destination "/var/log/system.log" with ASL Module "com.apple.asl".
ASL Module "com.apple.authd" claims selected messages.
ASL Module "com.apple.awdd" claims selected messages.
ASL Module "com.apple.callhistory.asl.conf" claims selected messages.
ASL Module "com.apple.cloudd" claims selected messages.
ASL Module "com.apple.clouddocs" claims selected messages.
ASL Module "com.apple.commerce.asl" claims selected messages.
ASL Module "com.apple.CoreDuetAdmissionControl" claims selected messages.
ASL Module "com.apple.eventmonitor" claims selected messages.
ASL Module "com.apple.family.asl" claims selected messages.
ASL Module "com.apple.ical" claims selected messages.
ASL Module "com.apple.icloud.FindMyDevice" claims selected messages.
ASL Module "com.apple.install" claims selected messages.
ASL Module "com.apple.iokit.power" claims selected messages.
ASL Module "com.apple.mail" claims selected messages.
ASL Module "com.apple.MessageTracer" claims selected messages.
ASL Module "com.apple.networking.symptoms" claims selected messages.
May 10 08:38:21 --- last message repeated 1 time ---
ASL Module "com.apple.performance" claims selected messages.
ASL Module "com.apple.sandbox.telemetry" claims selected messages.
ASL Module "com.apple.secinitd" claims selected messages.
ASL Module "com.apple.securityd" claims selected messages.
May 10 08:38:22 --- last message repeated 6 times ---
May 10 08:38:21 Orestes-del-Castillos-iMac.local CalendarAgent[246]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:21 Orestes-del-Castillos-iMac.local com.apple.iCloudHelper[1022]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:22 Orestes-del-Castillos-iMac.local com.apple.iCloudHelper[1022]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
May 10 08:38:23 Orestes-del-Castillos-iMac.local com.apple.iCloudHelper[1022]: AOSKit ERROR: Setup request failed, appleID=odcstudio, url=https://setup.icloud.com/setup/login_or_create_account, requestHeaders=
"X-Apple-MD" = "";
"X-Mme-Nas-Qualify" = "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";
error=Error Domain=AOSErrorDomain Code=1000 "The operation couldn’t be completed. (AOSErrorDomain error 1000.)" UserInfo=0x7ffe0a425640 {HttpStatusCode=401, DialogInfo={
Date = "Sun, 10 May 2015 12:38:23 GMT";
"X-Apple-Request-UUID" = "52ce9b93-6bb0-49fe-9c54-ac13c54f4cdd";
responseBody=
<dict>
<string>2</string>
<string>OK</string>
<key>Body</key>
<key>ErrorID</key>
<string></string>
<string></string>
<string></string>
<key>Header</key>
<string></string>
</dict>
</plist>
May 10 08:38:23 Orestes-del-Castillos-iMac.local CalendarAgent[246]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:23 Orestes-del-Castillos-iMac.local com.apple.iCloudHelper[1022]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:24 Orestes-del-Castillos-iMac.local CalendarAgent[246]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:25 Orestes-del-Castillos-iMac.local com.apple.iCloudHelper[1022]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:25 Orestes-del-Castillos-iMac kernel[0]: ZBAVKauth: pending entry not found for [0xffffff801d0d25a0]
May 10 08:38:25 Orestes-del-Castillos-iMac kernel[0]: ZBAVKauth: [0xffffff801d0d25a0] entry is missing
May 10 08:38:25 Orestes-del-Castillos-iMac.local nsurlstoraged[250]: realpath() returned NULL for /var/root/Library/Caches/ocspd
May 10 08:38:25 Orestes-del-Castillos-iMac.local nsurlstoraged[250]: The read-connection to the DB=/var/root/Library/Caches/ocspd/Cache.db is NOT valid. Unable to determine schema version.
May 10 08:38:25 --- last message repeated 1 time ---
May 10 08:38:25 Orestes-del-Castillos-iMac.local nsurlstoraged[250]: ERROR: unable to determine file-system usage for FS-backed cache at /var/root/Library/Caches/ocspd/fsCachedData. Errno=13
May 10 08:38:25 Orestes-del-Castillos-iMac.local CalendarAgent[246]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:26 Orestes-del-Castillos-iMac.local locationd[79]: Location icon should now be in state 'Inactive'
May 10 08:38:26 Orestes-del-Castillos-iMac.local CalendarAgent[246]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:26 Orestes-del-Castillos-iMac.local com.apple.iCloudHelper[1022]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:27 Orestes-del-Castillos-iMac.local com.apple.iCloudHelper[1022]: AOSKit ERROR: Setup request failed, appleID=odcstudio, url=https://setup.icloud.com/setup/login_or_create_account, requestHeaders=
"X-Apple-MD" = "";
"X-Mme-Nas-Qualify" = "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";
error=Error Domain=AOSErrorDomain Code=1000 "The operation couldn’t be completed. (AOSErrorDomain error 1000.)" UserInfo=0x7ffe0a60a590 {HttpStatusCode=401, DialogInfo={
Date = "Sun, 10 May 2015 12:38:27 GMT";
"X-Apple-Request-UUID" = "cbeae918-ba4a-4fb1-959a-45f6787d3b66";
responseBody=
<dict>
<string>2</string>
<string>OK</string>
<key>Body</key>
<key>ErrorID</key>
<string></string>
<string></string>
<string></string>
<key>Header</key>
<string></string>
</dict>
</plist>
May 10 08:38:27 Orestes-del-Castillos-iMac.local CalendarAgent[246]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:27 Orestes-del-Castillos-iMac.local com.apple.iCloudHelper[1022]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:28 Orestes-del-Castillos-iMac.local com.apple.iCloudHelper[1022]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:28 Orestes-del-Castillos-iMac.local CalendarAgent[246]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:29 Orestes-del-Castillos-iMac.local com.apple.iCloudHelper[1022]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:29 Orestes-del-Castillos-iMac.local CalendarAgent[246]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:30 Orestes-del-Castillos-iMac.local com.apple.iCloudHelper[1022]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:30 Orestes-del-Castillos-iMac.local CalendarAgent[246]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:31 Orestes-del-Castillos-iMac.local com.apple.iCloudHelper[1022]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:32 Orestes-del-Castillos-iMac.local com.apple.iCloudHelper[1022]: AOSKit ERROR: Setup request failed, appleID=odcstudio, url=https://setup.icloud.com/setup/login_or_create_account, requestHeaders=
"X-Apple-MD" = "";
"X-Mme-Nas-Qualify" = "AsWAhPgL9CwTImVewddOQkrxdy0EGQ/JC022nEK0AeiaAAABYAUAAAABAAABAGFKboXMLOFQeuL3ZYHBfTVqP9GbnP3LnYBlQ5WnZjp8cXtfMkktsbd7aO4YshDSZ0CTRO2PnEOJ8MkG+FkhLF4zrTuaaYqAK/6UMN102WcXOOv/8Gg8mbtzNW0Kfr0NdF7s0fzlPZN6qkdXxZItiZwQkwRnvJRkH101Wd8a/7RqLIC9kIUBf3JR0ha1/VT8QtjUCLPF3ZeN9lD8qBQErJXbNFOo2U0cfR5kxCMNGqg0o6WjSctKtu/hIfmVUoIlzJpZuBPzZjp1zVNX0Q9XCRb/qZk90VqTWKVL5c4ddSSWK5viAiI4QUb2lfEfK0QnFm7pd08h6qAv3F9C54K6nS4AAAAAAAAATwEMO4WiMbaJg1606/t9Gt0EfjmInAAAADYDBvbtPWwGf6KRqgQ2hhhI7jlVT1FH4VXxvEWnNPXuLNNqIdLtOAssgOblkbQTu6ybohsFcSE=";
error=Error Domain=AOSErrorDomain Code=1000 "The operation couldn’t be completed. (AOSErrorDomain error 1000.)" UserInfo=0x7ffe0a5286b0 {HttpStatusCode=401, DialogInfo={
Date = "Sun, 10 May 2015 12:38:31 GMT";
"X-Apple-Request-UUID" = "d2204c57-56b6-4e83-966d-a2ed8db6d1c3";
responseBody=
<dict>
<string>2</string>
<string>OK</string>
<key>Body</key>
<key>ErrorID</key>
<string></string>
<string></string>
<string></string>
<key>Header</key>
<string></string>
</dict>
</plist>
May 10 08:38:32 Orestes-del-Castillos-iMac.local CalendarAgent[246]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:33 Orestes-del-Castillos-iMac.local com.apple.iCloudHelper[1022]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:33 Orestes-del-Castillos-iMac.local CalendarAgent[246]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:34 Orestes-del-Castillos-iMac.local CalendarAgent[246]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:34 Orestes-del-Castillos-iMac com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
May 10 08:38:34 Orestes-del-Castillos-iMac.local com.apple.iCloudHelper[1022]: AOSKit WARN: Zero-length password passed to AOSAccountCreate (odcstudio)
May 10 08:38:35 Orestes-del-Castillos-iMac.local CalendarAgent[246]: [com.apple.calendar.store.log.caldav.queue] [Account refresh failed with error: Error Domain=CoreDAVHTTPStatusErrorDomain Code=401 "The operation couldn’t be completed. (CoreDAVHTTPStatusErrorDomain error 401.)" UserInfo=0x7f83a3da0090 {AccountName=odcstudio@me.com, CalDAVErrFromRefresh=YES, CoreDAVHTTPHeaders=<CFBasicHash 0x7f83a6157560 [0x7fff78ea2ed0]>{type = immutable dict, count = 7,
entries =>
0 : Server = <CFString 0x7f83a3d5f3d0 [0x7fff78ea2ed0]>{contents = "iCloudCalendarServer 15B64"}
1 : Content-Type = <CFString 0x7f83a3d92340 [0x7fff78ea2ed0]>{contents = "text/html;charset=utf-8"}
2 : X-Responding-Server = <CFString 0x7f83a3d39a00 [0x7fff78ea2ed0]>{contents = "st11p09me-caldav017 7 a63660a6f7d1a25b5a7ed66dab0da843"}
3 : X-Transaction-Id = <CFString 0x7f83a3d796a0 [0x7fff78ea2ed0]>{contents = "702ee136-f711-11e4-952f-3cd92bfaaef4"}
6 : Date = <CFString 0x7f83a3d578a0 [0x7fff78ea2ed0]>{contents = "Sun, 10 May 2015 12:38:19 GMT"}
9 : Www-Authenticate = <CFString 0x7f83a3d8d750 [0x7fff78ea2ed0]>{contents = "x-mobileme-authtoken realm="MMCalDav", basic realm="MMCalDav""}
10 : Content-Length = 141
May 10 08:38:35 Orestes-del-Castillos-iMac.local CalendarAgent[246]: [com.apple.calendar.store.log.caldav.queue] [Coalescing failed operation [<CalDAVAccountRefreshQueueableOperation: 0x7f83a3d927b0; Sequence: 0>]]
May 10 08:38:36 Orestes-del-Castillos-iMac.local com.apple.backupd[5056]: Starting automatic backup
May 10 08:38:40 Orestes-del-Castillos-iMac com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
May 10 08:38:41 Orestes-del-Castillos-iMac.local com.apple.backupd[5056]: Backing up to /dev/disk1s2: /Volumes/LACIE SETUP/Backups.backupdb
May 10 08:38:48 Orestes-del-Castillos-iMac kernel[0]: ZBAVKauth: [0xffffff801c620780] daemon response timeout
May 10 08:38:55 Orestes-del-Castillos-iMac com.apple.xpc.launchd[1] (com.apple.quicklook[5059]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook
May 10 08:38:55 Orestes-del-Castillos-iMac kernel[0]: ZBAVKauth: pending entry not found for [0xffffff801e601f00]
May 10 08:38:55 Orestes-del-Castillos-iMac kernel[0]: ZBAVKauth: [0xffffff801e601f00] entry is missing
May 10 08:38:56 Orestes-del-Castillos-iMac.local thermald[44]: invalid attribute or value, default to yes
May 10 08:38:56 Orestes-del-Castillos-iMac.local nbagent[5017]: XPC Activity invoked with state=2
May 10 08:38:57 Orestes-del-Castillos-iMac.local storeaccountd[355]: AccountServiceDelegate: Accepting new connection <NSXPCConnection: 0x7fbd8bc62550> connection from pid 5017 with interface <AccountServiceInterface: 0x7fbd8bc2c090> (PID 5017)
May 10 08:38:59 Orestes-del-Castillos-iMac.local nsurlsessiond[247]: Being asked if container with identifier com.apple.clouddocs.com.apple.TextInput is foreground before getting callback from BRContainersMonitor!
May 10 08:39:00 --- last message repeated 1 time ---
May 10 08:39:00 Orestes-del-Castillos-iMac.local nsurlsessiond[247]: Being asked if container with identifier com.apple.clouddocs.com.apple.Preview is foreground before getting callback from BRContainersMonitor!
May 10 08:39:07 --- last message repeated 1 time ---
May 10 08:39:07 Orestes-del-Castillos-iMac com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
May 10 08:39:07 Orestes-del-Castillos-iMac kernel[0]: ZBAVKauth: pending entry not found for [0xffffff8014a053c0]
May 10 08:39:07 Orestes-del-Castillos-iMac kernel[0]: ZBAVKauth: [0xffffff8014a053c0] entry is missing
May 10 08:39:08 Orestes-del-Castillos-iMac com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
May 10 08:39:09 Orestes-del-Castillos-iMac kernel[0]: ZBAVKauth: pending entry not found for [0xffffff8012455690]
May 10 08:39:09 Orestes-del-Castillos-iMac kernel[0]: ZBAVKauth: [0xffffff8012455690] entry is missing
May 10 08:39:09 Orestes-del-Castillos-iMac.local storeaccountd[355]: ADI: {
"Accept-Ranges" = bytes;
"Cache-Control" = "max-age=14400";
Connection = "Keep-Alive";
"Content-Language" = "en-us";
"Content-Length" = 793;
"Content-Type" = "application/x-apple-plist";
Date = "Sun, 10 May 2015 12:39:09 GMT";
Etag = "\"e20-5071070ddab80\"";
Expires = "Sun, 10 May 2015 16:39:09 GMT";
"Keep-Alive" = "timeout=15, max=312";
"Last-Modified" = "Tue, 04 Nov 2014 23:01:18 GMT";
Server = Apache;
May 10 08:39:16 Orestes-del-Castillos-iMac.local WindowServer[177]: Surface testing disallowed updates for 10 sequential attempts...
May 10 08:39:16 Orestes-del-Castillos-iMac.local WindowServer[177]: Surface test allowed updates after 11 attempts
May 10 08:39:21 Orestes-del-Castillos-iMac.local periodic-wrapper[5015]: Running daily periodic task.
May 10 08:39:22 Orestes-del-Castillos-iMac.local sandboxd[338] ([5065]): nbstated(5065) deny ipc-posix-shm-read-data com.apple.AppleDatabaseChanged
May 10 08:39:23 Orestes-del-Castillos-iMac.local com.apple.backupd[5056]: Will copy (2.5 MB) from Macintosh HD
May 10 08:39:23 Orestes-del-Castillos-iMac.local com.apple.backupd[5056]: Found 180 files (2.5 MB) needing backup
May 10 08:39:23 Orestes-del-Castillos-iMac.local com.apple.backupd[5056]: 1.15 GB required (including padding), 3.61 TB available
May 10 08:39:42 Orestes-del-Castillos-iMac.local AutoCAD LT 2015[5069]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.3 instead of 10.10.3. Use NSProcessInfo's operatingSystemVersion property to get correct system version number.
Call location:
May 10 08:39:42 Orestes-del-Castillos-iMac.local AutoCAD LT 2015[5069]: 0 CarbonCore 0x00007fff965ee2b7 ___Gestalt_SystemVersion_block_invoke + 113
May 10 08:39:42 Orestes-del-Castillos-iMac.local AutoCAD LT 2015[5069]: 1 libdispatch.dylib 0x00007fff8ac34c13 _dispatch_client_callout + 8
May 10 08:39:42 Orestes-del-Castillos-iMac.local AutoCAD LT 2015[5069]: 2 libdispatch.dylib 0x00007fff8ac34b26 dispatch_once_f + 117
May 10 08:39:42 Orestes-del-Castillos-iMac.local AutoCAD LT 2015[5069]: 3 CarbonCore 0x00007fff96577456 _Gestalt_SystemVersion + 987
May 10 08:39:42 Orestes-del-Castillos-iMac.local AutoCAD LT 2015[5069]: 4 CarbonCore 0x00007fff965766e3 Gestalt + 144
May 10 08:39:42 Orestes-del-Castillos-iMac.local AutoCAD LT 2015[5069]: 5 QtCore 0x000000010a097916 _GLOBAL__I_a + 22
May 10 08:39:42 Orestes-del-Castillos-iMac.local AutoCAD LT 2015[5069]: 6 ??? 0x00007fff65f9dceb 0x0 + 140734904261867
May 10 08:40:00 Orestes-del-Castillos-iMac com.apple.xpc.launchd[1] (com.apple.quicklook[5140]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook
May 10 08:40:12 Orestes-del-Castillos-iMac.local Console[5144]: Failed to connect (_consoleX) outlet from (NSApplication) to (ConsoleX): missing setter or instance variable
May 10 08:40:19 Orestes-del-Castillos-iMac.local AutoCAD LT 2015[5069]: ApplePersistenceIgnoreState: Existing state will not be touched. New state will be written to /var/folders/bs/7dn5g28n1qsbfsx28xj52hrr0000gn/T/com.autodesk.AutoCADLT2015_StandAlone.savedState
May 10 08:40:21 Orestes-del-Castillos-iMac.local networkd[176]: -[NETDuetGate admissionCheck] admissionCheckOfValue failed: Error Domain=Timed out waiting for XPC and/or reply handler Code=104 "The operation couldn’t be completed. (Timed out waiting for XPC and/or reply handler error 104.)"
May 10 08:40:23 Orestes-del-Castillos-iMac.local WindowServer[177]: disable_update_timeout: UI updates were forcibly disabled by application "Console" for over 1.00 seconds. Server has re-enabled them.
May 10 08:40:24 Orestes-del-Castillos-iMac.local WindowServer[177]: common_reenable_update: UI updates were finally reenabled by application "Console" after 2.45 seconds (server forcibly re-enabled them after 1.00 seconds)
May 10 08:40:28 Orestes-del-Castillos-iMac kernel[0]: ZBAVKauth: pending entry not found for [0xffffff8019e23a50]
May 10 08:40:28 Orestes-del-Castillos-iMac kernel[0]: ZBAVKauth: [0xffffff8019e23a50] entry is missing
May 10 08:40:29 Orestes-del-Castillos-iMac kernel[0]: ZBAVKauth: pending entry not found for [0xffffff8019e23a50]
May 10 08:40:29 Orestes-del-Castillos-iMac kernel[0]: ZBAVKauth: [0xffffff8019e23a50] entry is missing
May 10 08:40:32 Orestes-del-Castillos-iMac.local FNPLicensingService[5151]: Started - This service performs licensing functions on behalf of FlexNet enabled products.
May 10 08:40:34 Orestes-del-Castillos-iMac.local FlexNet Licensing Service[5151]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.3 instead of 10.10.3. Use NSProcessInfo's operatingSystemVersion property to get correct system version number.
Call location:
May 10 08:40:34 Orestes-del-Castillos-iMac.local FlexNet Licensing Service[5151]: 0 CarbonCore 0x00007fff965ee2b7 ___Gestalt_SystemVersion_block_invoke + 113
May 10 08:40:34 Orestes-del-Castillos-iMac.local FlexNet Licensing Service[5151]: 1 libdispatch.dylib 0x00007fff8ac34c13 _dispatch_client_callout + 8
May 10 08:40:34 Orestes-del-Castillos-iMac.local FlexNet Licensing Service[5151]: 2 libdispatch.dylib 0x00007fff8ac34b26 dispatch_once_f + 117
May 10 08:40:34 Orestes-del-Castillos-iMac.local FlexNet Licensing Service[5151]: 3 CarbonCore 0x00007fff96577456 _Gestalt_SystemVersion + 987
May 10 08:40:34 Orestes-del-Castillos-iMac.local FlexNet Licensing Service[5151]: 4 CarbonCore 0x00007fff965766e3 Gestalt + 144
May 10 08:40:34 Orestes-del-Castillos-iMac.local FlexNet Licensing Service[5151]: 5 FNPLicensingService 0x0000000100016580 FNPLicensingService + 91520
May 10 08:40:34 Orestes-del-Castillos-iMac.local FlexNet Licensing Service[5151]: 6 FNPLicensingService 0x0000000100015ea9 FNPLicensingService + 89769
May 10 08:40:37 Orestes-del-Castillos-iMac kernel[0]: ZBAVKauth: pending entry not found for [0xffffff8019860870]
May 10 08:40:37 Orestes-del-Castillos-iMac kernel[0]: ZBAVKauth: [0xffffff8019860870] entry is missing
May 10 08:40:39 Orestes-del-Castillos-iMac.local LMU[5157]: 5157 DAEMONIZE: setting umask 0
May 10 08:40:39 Orestes-del-Castillos-iMac.local LMU[5157]: 5157 DAEMONIZE: session parent exiting
May 10 08:40:39 Orestes-del-Castillos-iMac.local LMU[5157]: exiting and supressing hooks: 0
May 10 08:40:39 Orestes-del-Castillos-iMac.local LMU[5158]: 5158 DAEMONIZE: session new session leader
May 10 08:40:39 Orestes-del-Castillos-iMac.local LMU[5158]: 5158 DAEMONIZE: tty disconnect parent exiting
May 10 08:40:39 Orestes-del-Castillos-iMac.local LMU[5159]: 5159 DAEMONIZE: tty disconnect child
May 10 08:40:39 Orestes-del-Castillos-iMac.local LMU[5159]: 5159 DAEMONIZE: closing file descriptors
May 10 08:40:39 Orestes-del-Castillos-iMac.local LMU[5159]: 5159 Execing /Applications/Autodesk/Adlm/R9/LMU.app/Contents/MacOS/lmuopen
May 10 08:40:39 Orestes-del-Castillos-iMac.local LMU[5159]: 5159 with argument: lmuopen
May 10 08:40:39 Orestes-del-Castillos-iMac.local LMU[5159]: 5159 with argument: /Applications/Autodesk/Adlm/R9/LMU.app/Contents/MacOS/LMU
May 10 08:40:39 Orestes-del-Castillos-iMac kernel[0]: ZBAVKauth: pending entry not found for [0xffffff8019e23a50]
May 10 08:40:39 Orestes-del-Castillos-iMac kernel[0]: ZBAVKauth: [0xffffff8019e23a50] entry is missing
May 10 08:40:39 Orestes-del-Castillos-iMac.local lmuopen[5159]: Launching: /Applications/Autodesk/Adlm/R9/LMU.app/Contents/MacOS/LMU
May 10 08:40:40 Orestes-del-Castillos-iMac com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
OdCStudio
Sorry for the length of the previous post, I didn't realize that it had copied so much stuff from the console app.
The other part, I have never used the AutoCAD log in account to "log in" into my subscription. I used it just by opening the program, with the page for Autodesk open in the background or not. Mainly not.
I could create another account, but please guide me here, how would it help solve the problem if the action of opening the program is not linked to the identy used online since I am not accessing the program onlime.
I will try that right now and will let you know, thanks.
OdCStudio
Thanks Maxim, for all your efforts.
I created a new account id for Autodesk. Try to open my AutoCAD LT 2015, it didn't work either. What really puzzles me is that it was working properly before, and now for some reason it seems not to be recognized or something similar.
I would like to solve this, or I will have to learn another drafting and design program.
Thanks so much.
maxim_k
I meant to create new account on your Mac, but not new Autodesk ID. But after looking at System.log,
I think there is no need to try with different account, because from the System.log I see that there is a problem with AutoCAD license manager on your Mac for some reason. Looks like it tries to activate AutoCAD session but fails.
I am not aware how activation process works with rental license (I suppose you have such kind of lisence).
For proprietary standalone licence there is a method for resetting AutoCAD license. Please look at this topic - my last post after I wrote about resetting AutoCAD :
http://forums.autodesk.com/t5/autocad-for-mac-general/autocad-for-mac-2014-2013-etc-crashing-at-star...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
OdCStudio
Thanks Maxim, I am going to the Apple Store to seek some help -if they have any help- with these problems. Your diagrams looked very different from what shows in my screen. Thanks so mucho for all your guidance.
great!!! THANKS
Crashing issue is persisting for me consistently for about 4 months now. The OpenGL trick did not help at all. Issue occurs with every single drawing I attempt to create in AutoCAD 2015. All are simple/complex 2D drawings. Crashes are reproducible, usually occur during simple act of drawing a line or shape, and frequently when attempting to rotate a line. Also, when attempting to save a file, AutoCAD crashes every single time and doesn't actually save any progress, so at this point the program is useless. Crashes usually occur with CER, and I have submitted reports every time but have never received an email back informing me that a fix is available. Crashes like this have occurred since I first updated to Yosemite and have persisted on every single version including the most recent (10.10.5). My Mac configuration is as follows: 15" MBP, Mid 2012 2.7 GHz Intel Core i7 8GB RAM NVIDIA GeForce GT 650M 1024 MB Troubleshooting I have tried: Enabling OpenGL in Preferences>General. Uninstall and reinstall AutoCAD 2015. Reinstall OS X. Please any help would be greatly appreciated. I can no longer use this product in it's current condition and it is 100% necessary for my schooling. Thank you for any help.
EDIT: I have updated AutoCAD with the 2 Maintenance Updates. Crashing persists when attempting to save 2D drawing and when I attempt to view/add more layers to a drawing. Also tried more troubleshooting on my own: launched AutoCAD in safe mode (holding shift on launch) and tested issue in new user admin account, all issues persist.
maxim_k
Welcome to Autodesk Forums!
I cannot advice you anything, because you've tried all possible solutions to the problem yourself. Except one - try to use AutoCAD for Mac on another Mac.
I personally used AutoCAD on several Macs and never had issues you described.
BTW : how much free space is on your Mac hard drive?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
I had all the same issues you have. What I did, and in fact, what worked, was to click on active OpenGL Core profile in preferences. If you have it active,deactive restart autocad and active it again... And finally restart autocad. It really works.
Hi Timothy,
This might sound like a weird question but what mouse are you using? First i used a Trust mouse which caused a lot of bugs in AutoCad. Just try a (new) logitech mouse from a friend before you throw your Mac out of the window.
Good luck man.
Jeroen
I have over 700GB of free space on my internal HD. I do not have the ability to use another Mac, this is my only computer and I really don't see the point in having to purchase a whole other computer just to use AutoCAD. I have had scores of classmates with very similar issues. It is a shame that AutoDesk provides so little in ways of support for their products. My only choice, at this point, will be to install AutoCAD on my Windows 10 partition, which honestly is a massive inconvenience.
As stated before, I already tried that. It did not help in any noticeable way.
