AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
AUTOCAD 2015 for mac can't open default template
8 REPLIES 8
Message 1 of 9
678 Views, 8 Replies
I've a regular student license for autocad 2015. I installed it several times, I also did the clean Unistall following the instruction, but I always have a big problem: I can't open the default templates. Every time I try the program closes. I tried opening from downloaded files but it didn't work either. I don't know what to do. I can only open tutorials and sheetsets, but I can't open templates, that I see black in the preview (see the pic).
Please help me, it's driving me crazy. (my mac is a OS X 10.9.5)
8 REPLIES 8
Message 2 of 9
Emmsleys
Thats odd, by any chance did you change the file path where the templates are stored?
Sarah Emmsley
Technical Support Specialist
Message 3 of 9
maxim_k
Welcome to Autodesk Forums!
What happens if you choose "Cancel" from the Welcome screen? Are you able to work in AutoCAD?
I mean:
- are you able to create new drawings with NEW command (menu File -> New)?
- are you able to open existing drawings with OPEN command (menu File -> Open)?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 4 of 9
in reply to: maxim_k
I tried, it does the same: the program closes without any message of error.
Message 5 of 9
in reply to: Emmsleys
I don't think so, but I can check. Now the templates are in: Library>Application support>Autodesk>local>Autocad 2015>R20.0>enu>Template
They are all in black in the preview.
Message 6 of 9
maxim_k
So you are not able to work with AutoCAD at all?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 9
I can only open tutorials. So basically I can't do anything on it.
Message 8 of 9
maxim_k
Tutorials are not drawings.
Try this:
- create new account on your Mac - you need regular account, not Guest
- login to this new account and try to launch AutoCAD, than create new drawing or open existing.
Does it works?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 9
Emmsleys
So you are unable to work on any drawing files at all?
Has this happened in the past with other student versions of AutoCAD?
Were you able to try the suggestion made by Maxim?
Sarah Emmsley
