Auto Cad LT suddenly running very slow
No aplicable
A few weeks ago, out of nowhere my AutoCAD LT just started running very slow.  Every time I pull a dimension line the rainbow wheel spins for 30 seconds.  Not Good...  It happened instantly one day.  I'm running on a iMac pro which has great processing and a high-performance upgraded video card so I don't think my computer is the issue...  Any ideas on what is going on?  Thx!
0 Me gusta
Responder
Soluciones aceptadas (2)
1.382 Vistas
20 Respuestas
Respuestas (20)
No aplicable
0 Me gusta
pendean
Community Legend
Community Legend
Your LT year version is...?
Your MacOS version is...?
Is the problem in ALL files, or just this one?
Is the problem in all command, or just when dimensioning?
0 Me gusta
No aplicable
AutoCAD LT 2021
MacOS 11.2.3
All Files
Not all commands but any that involve any calculating like Dimensioning
0 Me gusta
maxim_k
Solución aceptada
Hi @Anonymous ,
I think you should try to clear all blocks from Recent Blocks tab of Blocks palette: right-click on empty space in that tab and select "Clear all" from context menu.
To stop population of Recent blocks tab with recently inserted blocks set System variable BLOCKMRULIST=0 (zero).
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
No aplicable
Yep.  I think that did it.  How do I get to "System Variable BLOCKMRULIST"?  Thx!!!
0 Me gusta
maxim_k
@Anonymous
At the Command Window type BLOCKMRULIST and hit Return, then type 0 and hit return again:
Command: BLOCKMRULIST
Enter new value for BLOCKMRULIST <50>: 0
Command:
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
No aplicable
Thank you!!!
0 Me gusta
No aplicable
Your previous directions regarding clearing the blocks helped a lot on the files I was work on before but I just opened another file and it's running quite glitchy again.  Pulling dimension lines is not an issue anymore but the curser as I move and select items is rather glitchy and jumping around.  Any suggestions here?  Thx again.  Neiel
0 Me gusta
maxim_k
@Anonymous
Verify if you have SNAP turned ON - F9 key toggles it.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Yeah, I checked that.  The grid snap is not on but it's jumping around similar to as if it was...
0 Me gusta
maxim_k
Do you have this problem in all drawings? Even in newly created?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
maxim_k
Check once again that system variable SNAPMODE=0
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Yes.  Snap mode is <0>.  Sitll Glitchy
0 Me gusta
maxim_k
Again: Do you have this problem in all drawings? Even in newly created?
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
It's actually all files.  I opened up a fresh one and I have the same issues...
0 Me gusta
maxim_k
If you are sure that there is no blocks on Recent tab of Blocks palette and
you don't use external display with low refresh rate, you can try to Reset
AutoCAD.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
What happens if I reset AutoCAD?  Will I lose all my settings?  I guess I may have to...
0 Me gusta
maxim_k
Yes, you will loose your customization (settings). But AutoCAD creates an
archive with custom settings and it is possible to restore them if
resetting won't help.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Solución aceptada
I reset AutoCAD and it looks like the glitch is gone.  Thx!  Neiel
0 Me gusta
