Auto Cad for Mac 2013, 2014, 2015
No aplicable
Can you tell me? Autocad for Mac 2013, 2014 and 2015 versions, are they very different to use? In my college, they are using 2013 version(for PC, not Mac). And I'm  ot sure which one I should install. If I work on college's computer, can I also work on my mac? or would it be a problem?
Give me an advice!
0 Me gusta
Responder
1.162 Vistas
15 Respuestas
Respuestas (15)
maxim_k
My advice is to install and use 2015 version of AutoCAD for Mac.
Probably you know that AutoCAD for Mac lacks some of the features of the PC version and in 2015 version a lot of such features were added to AutoCAD for Mac. Plus 2015 version is fully compatible with Mavericks and Yosemte and is more stable than earlier releases.
File formats are the same for 2013, 2014 and 2015 releases (on Mac and PC)
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Thanks for the advice! I was a bit confused at first when I tried to use Autocad for mac(any versions) that I had to choose a template to start. Because when I clicked New , it didn't show a kind of blank drawing board, just had to choose a template. As for PC, if i select New, a blank drawing came out.
Is it normal?
0 Me gusta
maxim_k
The NEW command (which you use on Mac to start new drawing) on PC version opens "Select drawing template" dialog too. So there is no difference here and it is normal.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Right. But then I'm not sure which one is the best to use for my case. I'm doing mechanical engineering, and using 'mm' rather than the Imperial inches.If you            know which is the best to use, can you let me know?
I
0 Me gusta
maxim_k
acadiso.dwt is what you need.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Thank you so much, Maxim!!!!! You are so helpful. Really thanks!
0 Me gusta
No aplicable
Hi, again. I have another question. I got a notification about Update 2  for Autocad Mac. Should I install it?
If you know, please let me know...
0 Me gusta
maxim_k
Yes, you need to install it as it contains some useful fixes:
http://knowledge.autodesk.com/sites/default/files/file_downloads/AutoCAD_2015_and_AutoCAD_LT_2015_Fo...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
You are so so helpful, and thank you so much again!( Sorry, I keep asking you one after another.)
0 Me gusta
No aplicable
Sorry again...The instruction said 'Double-click AutoCAD2015Update2_English.dmg', but where can I find this page?
And at first do I have to uninstall Autocad for MAc 2015?
0 Me gusta
maxim_k
No, you don't need to uninstall AutoCAD.
If you downloaded Update when AutoCAD was running, than quit AutoCAD, then look for AutoCAD2015Update2_English.dmg file in your Downloads folder, double click it to mount installation image, than double click pkg file inside it to start update.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Right. (sorry I didn't have time to check and reply straight away). I will try to see. Thank you again!( I might ask you again...)
0 Me gusta
No aplicable
'Hi. Sorry again. I can't find the link to install Update 2 version. I click the link you gave me, and click 'Apply  This update ', but nothing happens, just scrolls down to the info below on that page...Where can I find it to actually update?
0 Me gusta
maxim_k
It was the link to Readme for this update, and here is the link to the update itself:
http://knowledge.autodesk.com/sites/default/files/file_downloads/AutoCAD2015Update2_English.dmg
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
You are my Mr. Autocad!!
Thank you! (If you had enough, just say so...)
0 Me gusta
