When I batch publish a set of drawings with 2017 LT for mac, the resulting file when printed has very light line weights. If I just print one pdf from the drawing layout, the final print is fine.
When the page setup manager setting for "print object line weight" is checked, I can print directly from the layout, or "save" a single pdf and then print - and the printed line weight is fine. When a batch publish of multiple drawings to pdf is tried with this setting, the drawings have a very dark, ilegible line weight. Turning off the "print object line weight" box, the resulting pdf batch publish of multiple drawings looks fine on the screen , but then prints as a very light version, almost too light to read.
Has anyone encountered this or know how to fix it? I did not have these problems with an earlier 2013 Autocad Lt for Mac version.
Solved by maxim_k. Go to Solution.
Hi Maxim,
I use the monochrome.ctb in the Plot Style Table in the Page Setup. I batch publish to the PDF.
An example printed drawing is attached.
Mark
Following up on your thread, were you able to find a solution or a workaround?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Or post with any new updates if you need continued help on your thread.
Thanks for your time.
Maxim,
Attached is a 2017 ACADLT for Mac drawing file example. Also attached are two pdfs - one taken from a direct pdf print and another from a batch publish pdf print. Note that they both have line weights that are too "light". It is only when I do a direct print to the printer and change the page setup manager option to check the "print objects line weight" under print options that I can get a print with the proper line weights. If I use this same setting and print a pdf I get a drawing that is illegible with very dark line weights.
Attached is an ACAD file, a pdf print, and a pdf "batch publish" print.
Mark
Hi Mark,
I created new page setup in your drawing - Setup1 - with these settings:
and got acceptable output with Batch publish (see attached PDF).
Maxim
