Anuncios
Attributes default location
rsimx123
rsimx123
When I edit an attribute, (in the attribute editor) how do I default into the value field? Currently I have to manually click inside the value field first, then type a value. Too much clicking. slows me way down.
0 Me gusta
Responder
Soluciones aceptadas (1)
244 Vistas
2 Respuestas
Respuestas (2)
maxim_k
Solución aceptada
Hi @rsimx123 ,
Do you mean that on Mac when you double-click on attribute inside block with multiple attributes, it opens dialog for editing attributes, but double clicked attribute is not selected in it?
If yes, then you can:
- Use Properties Palette for editing attributes. Just select block and look at the Attributes section on the Properties Palette
or
- Double-click the attribute while holding down the Ctrl key. In this case you can edit attribute right "in place", without opening dialog. AutoCAD starts ATTIPEDIT command in such case.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
rsimx123
Thanks, I also discovered ATTEDIT. As long as my attribute is a single line.
0 Me gusta
