Annotative Text Enlarging at Plot
I'm having a seemingly unsolvable problem while using annotative text.
I have text size set to 1/8" in an annotative text style and Annotation Scale set to 3/16". Text appears correctly (at 8") in modelspace.
Text also appears correctly in paperspace. Where I have an issue is when I go to plot. Text sizes up to 5/16" in both preview and finished plot. Text created in paperspace sizes correctly.
This occurs with both native AutoCAD fonts and downloaded fonts.
Any fix?
Lots of thanks.
maxim_k
Can you attach your problem drawing (or a part of it with annotative text)?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
pendean
Community Legend
Community Legend
PREVIEW will generally REGEN your file before displaying it: is your viewport scale actually set to what you think it is set to?
Yes, I'll DM it to you. Thanks for the help.
Yes, viewports are set to 3/16".
maxim_k
After examining the OP's drawing, the problem was solved by setting view direction perpendicular to the drawing plane inside viewport with PLANE command.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
