AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
acad.pat location
3 REPLIES 3
tranchellinim
30366 Views, 3 Replies
acad.pat location
Hello all!
I've struggled the whole day with this and I'd like to share the result to avoid someone else to do the same...
I needed to add paterns to my acad.pat file. Using the procedure that is included in the hatch command gave no result. The added paterns were never added. No luck?
Then I wanted to edit manually the acad.pat file. I used the command which is included in the hatch command that allows to reach the acad.pat file directly. I made the change to that acad.pat file whithout any success. I did the same in the acadiso.pat file that was also there. No success.
Serching on the web I finally came across a command that is
(findfile "acad.pat")
That was the trick...
The file I was sent to over the Search in the Finder option in the hatch command was in the folder named:
~/Library/Application Support/Autodesk/roaming/AutoCAD 2013/R19.0/fra/Support/acad.pat
The file that came out with the findfile command above sent me to this other folder:
/Applications/Autodesk/AutoCAD 2013/AutoCAD 2013.app/Contents/Resources/Support/acad.pat
The outcome of that is that I was trying to edit the wrong file...   Because AutoCAD sent me there!
Hope it helps someone!
At least the development team...
Regards
Michael
3 REPLIES 3
maxim_k
in reply to: tranchellinim
Hi Michael,
You are right in your case,
BUT in my installation of AutoCAD both "Find in Finder" option in Hatch Library drop-down list and AutoLISP statement (findfile "acad.pat") return the same path: "~/Library/Application Support/Autodesk/roaming/AutoCAD 2013/R19.0/enu/support/acad.pat".
And I know the case of such behavior - it is in "Support File Search Path" sequence. In my case "~/Library/Application Support/Autodesk/roaming/AutoCAD 2013/R19.0/enu/support" is in first place and "/Applications/Autodesk/AutoCAD 2013/AutoCAD 2013.app/Contents/Resources/Support" on the second place:
so AutoCAD at first searches "~/Library/Application Support/Autodesk/roaming/AutoCAD 2013/R19.0/enu/support" folder for support files (including acad.pat, acadiso.pat and others) and then it searches "/Applications/Autodesk/AutoCAD 2013/AutoCAD 2013.app/Contents/Resources/Support" folder.
In your case search sequence is quite opposite (don't know why).
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
ron0ryan1
CREATE a directory for all your new hatches, use Options, support file search path, ADD
add the new directory of hatches DONE
acad is a kluster f
pendean
in reply to: ron0ryan1
Excellent advise!
”Boost
