ACAD Mac 2012 not displaying select dialogue boxes
After using 2012 for a few months I have discovered that some dialogue boxes do not display but seem to act as if they are open. For example, if I initiate the style command, I get a quick glimpse of the dialogue box but then it disappears. The program then acts as if the command is active (all other pulldown menu items are greyed, command line shows the command, etc.) and I can't do anything else until I hit escape. This happens in several other commnads too: page set up manager, color, block, linewieght, scale list, just to nbame a few, but not others. For instance linetype, point styple, dimension style, etc., work as they should.  Any ideas?
Thanks in advance.
MacBook Pro, 2.53 GHz Intel Core 2 Duo, Lion 10.7.2
Hi
Ive got the same exact problem, and I cant find the solution, in one related topic http://forums.autodesk.com/t5/AutoCAD-for-Mac/LT2012-for-Mac-Dialog-Box-disappearing/td-p/3212836 one solution seems to work for others but not for me.  Any other solution.
Thanx!!
margie_lo
I am having the same problem and have tried what the other post recommended - no luck.  Has anyone found a solution to this??  When I input 'INSERT' in the command line I get an image of the first block listed in my drawing in the lower left corner of the screen.  I can toggle through the blocks already inserted in my drawing by using the arrows, but I cannot insert a new block.  I am finding more and more dialog boxes that just are not appearing at all:
PAGESETUP
Layer color manager
HATCH (visor shows up, but not the dialog box with full options)
I'm at a stand still - any have any ideas???
Hi, After a few days trying to solve this, what worked for me was to delete "com.autodesk.AutoCAD.plist"  (as mentioned here: http://forums.autodesk.com/t5/AutoCAD-for-Mac/LT2012-for-Mac-Dialog-Box-disappearing/m-p/3213286#M32...  AND another one but I cant remember if it  was "com.autodesk.AutoCAD.R18.2.ACAD-A032.409.plist" or "com.autodesk.AutoCAD.plist.lockfile".
Anyway what i can recomend you is to copy those files to a safe location, delete the ones inside your Library and restart autocad. If anything fails you just put those files back back.
Sorry for not posting before forgetting the exact files.
Had the same problem.  I had to switch which monitor was the primary one. it will create a phantom monitor if its backwards.
