Anuncios
ACAD LT 2018 For Mac - Ortho With Shift Key Problem
ian
ian
Hi all, I rarely post on here as I can usually find a solution, however this time I can't...
I've just installed LT 2018 for Mac and can no longer use the "shift" key whilst copying/moving etc to constrain to ortho or free movement.
If I use the shift key, the object disappears and I am prompted to set ortho mode which is annoying - I mainly use ortho on and just hit the shift key when I want to move something freely.
This operation also adds a little circle with a triangle inside next to the cursor Emoticono frustrado
Would this be a preference/setting I've overlooked or is it a glitch ?
Many thanks
ACAD LT 2018 for MAC
2015 iMac Retina 5k 27"
OS Sierra 10.12.6
0 Me gusta
Responder
Soluciones aceptadas (1)
2.715 Vistas
41 Respuestas
Respuestas (41)
maxim_k
Hi Ian,
I have full AutoCAD 2018 and cannot reproduce the issue you described.
If ORTHO is on on my side and I hold Shift key for some time during editing/drawing operations it allows me to turn ORTHO of temporary until I release Shift key.
At the command prompt I also see "Enter new value for ORTHOMODE <1>" but then ORTHO turns off automatically and the current command resume.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
ian
Hi Maxim
Thanks for the reply........ that's weird
I get the same message in the command prompt and also at the cursor.
I can hit enter and accept the ORTHOMODE command mid operation, but that permanently toggles ortho on/off
I've tried opening a new drawing to no avail and had a look through keyboard settings on my mac Emoticono loco
0 Me gusta
maxim_k
Have you tried to relaunch AutoCAD? Restart your Mac?
With Shift key pressed AutoCAD should automatically change value of JRTHOMODE sys var.
Maxim
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
ian
Hi
Just restarted and nothing changed
It's 9pm here and time to stop work - will have another try tomorrow, thanks for your help so far
Ian
0 Me gusta
maxim_k
You can also try to Reset AutoCAD, but then you will loose all customizations (if you have any).
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
ian
Well......
I've reset ACAD - no change
I've deleted and reinstalled ACAD - no change
I've downloaded it again and reinstalled - no change
For each of the above I did not migrate my settings and files to see if that was the cause
Is no-one else using ACAD LT for Mac having this issue please ?
0 Me gusta
maxim_k
Can you post screencast of what happens when you are trying to use Shift to toggle ORTHO mode?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
ian
Hi Maxim, I had to research how to do that haha
The attached shows a simple move, when I press and hold the shift button mid command, that's when the "enter new value for ORTHO" prompt occurs
I then right clicked to accept the mode change and moved in ortho
If you watch the ortho button bottom right, it toggles from off to on, which is correct - however when the command is complete it should return to "off" but it doesn't
In LT 2017 the button goes on and off according to whether shift is pressed, and there is no requirement for a prompt acceptance mid-command
Hope this explains
0 Me gusta
maxim_k
Can you post screenshot of the "Keyboard" pane of the macOS System Preferences opened in Keyboard tab?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
ian
Screenshot attached
Changing the "Use F1, F2 etc" setting has no effect on the problem
"cmd + L" works mid command but toggles on/off permanently, as does F8 when "Use F1, F2 etc" is ticked
0 Me gusta
maxim_k
Which keyboard are you using?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
maxim_k
If it is bluetooth Apple keyboard, can you check with some other keyboard (wired)?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
ian
It's a wired apple keyboard, not sure what it's called but photo attached
0 Me gusta
maxim_k
Can you try another keyboard?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
ian
Another (very old) keyboard tried - no joy I'm afraid
0 Me gusta
maxim_k
On my side I don't need to confirm ORTHO toggle when I use Shift override mode, it toggles in about a second after I start to hold down Shift key and stays in ORTHO mode until I release Shift key. And this is normal behavior. On your side, as I understand it doesn't toggle automatically while you hold Shift key (BTW - have you tried to hold it for longer time and wait for toggle moment?)
Downloading AutoCAD 2018 LT now in order to check on my side.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
ian
Yes, that's correct
In 2017 there was no delay at all, not even a second
I've tried holding the shift down for longer (>2min) and nothing
Thanks for all your assistance thus far, at least my left hand little finger's RSI is showing signs of improvement :cara_que_ríe_con_la_boca_abierta_y_los_ojos_sonrientes:
0 Me gusta
maxim_k
I installed 2018 version of AC LT and I'm able to reproduce the issue. Definitely it is a BUG in LT version.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
ian
Oh, it's reassuring it's not my system then
Thank you soooooo much for all your help - what should I do now please, I have never reported a bug
0 Me gusta
