Anuncios
ACAD LT 2018 For Mac - Ortho With Shift Key Problem
ian
ian
Hi all, I rarely post on here as I can usually find a solution, however this time I can't...
I've just installed LT 2018 for Mac and can no longer use the "shift" key whilst copying/moving etc to constrain to ortho or free movement.
If I use the shift key, the object disappears and I am prompted to set ortho mode which is annoying - I mainly use ortho on and just hit the shift key when I want to move something freely.
This operation also adds a little circle with a triangle inside next to the cursor Emoticono frustrado
Would this be a preference/setting I've overlooked or is it a glitch ?
Many thanks
ACAD LT 2018 for MAC
2015 iMac Retina 5k 27"
OS Sierra 10.12.6
0 Me gusta
Responder
Soluciones aceptadas (1)
2.705 Vistas
41 Respuestas
Respuestas (41)
ireneAZESA
How to I go about reporting this to Autodesk, as it is only an issue with AutoCad so it's not a hardware problem. I am thinking it's as a result of using a MacBook Pro with Touch Bar.
0 Me gusta
No aplicable
Hello Irene,
You should be able to go under the help menu in AutoCAD LT and "submit
feedback", or if you have an Autodesk account, log in, scroll all the way
down and go through the steps of contacting support.
Cheers,
J
