Anuncios
ACAD LT 2018 For Mac - Ortho With Shift Key Problem
ian
ian
Hi all, I rarely post on here as I can usually find a solution, however this time I can't...
I've just installed LT 2018 for Mac and can no longer use the "shift" key whilst copying/moving etc to constrain to ortho or free movement.
If I use the shift key, the object disappears and I am prompted to set ortho mode which is annoying - I mainly use ortho on and just hit the shift key when I want to move something freely.
This operation also adds a little circle with a triangle inside next to the cursor Emoticono frustrado
Would this be a preference/setting I've overlooked or is it a glitch ?
Many thanks
ACAD LT 2018 for MAC
2015 iMac Retina 5k 27"
OS Sierra 10.12.6
0 Me gusta
Responder
Soluciones aceptadas (1)
2.701 Vistas
41 Respuestas
Respuestas (41)
maxim_k
Solución aceptada
I reported it just now.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
ian
Excellent, thank you again
Ian
0 Me gusta
No aplicable
Thanks for running through this.  I'm having the same issue on my end.
0 Me gusta
No aplicable
Yes, I'm having the same problem too. Just upgraded to LT 2018 on Mac, thought it was something wrong with my system. Thanks for the update.
0 Me gusta
No aplicable
Same problem in Autocad LT 2018 - Any news on a patch ??
0 Me gusta
gogomatic
Observer
Observer
Same here.
I went through the preferences (on and on) and just kept wasting my time...should have tried this forum first. But at least it's good to know for the future
Thanks for taking an action on this one.
0 Me gusta
No aplicable
Looks like this issue has been fixed with the Hotfix update.
ian
It has indeed, sorry I forgot to update this thread
No aplicable
No problem, Ian. I thought I would update as I've been using the 2017
version and only just checked yesterday for an update. J
0 Me gusta
No aplicable
Dear Maxim--
Thank you for your impressive expertise, to say nothing of your patience. : )
Just started using AC LT 2018 for Mac.
Did the Ortho Shift override key get a fix, yet, to your knowledge? Having the same issue...
Just wondering.
Kind regards.
William
0 Me gusta
No aplicable
Hi William,
The issue was fixed with a hotfix update.  If you are still having issues, I would check for updates on your software and then go from there.
Cheers,
Justin
0 Me gusta
maxim_k
Hi William,
This Hotfix:
https://knowledge.autodesk.com/support/autocad-lt-for-mac/downloads/caas/downloads/content/autocad-l...
would resolve the issue with Ortho.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
ireneAZESA
After the update 2018.1 I have the problem back again that the Ortho doesn't toggle with the shift key???
0 Me gusta
ireneAZESA
I originally applied this hot fix to my Autocad 2018 and it worked (fixed Ortho toggles with shift key) but after applying the upgrade 2018.1 and my shift key no longer toggles Ortho?
0 Me gusta
maxim_k
Hi @ireneAZESA,
Just checked on my Mac and fixed Ortho toggle with shift key works fine on my side after 2018.1 update.
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
ian
Mine has been absolutely fine since and have installed 2018.1 update with no issues
0 Me gusta
No aplicable
Mine works fine as well - no issues since update - my version - 0.48.M.478
0 Me gusta
ireneAZESA
Thanks guess I should start troubleshooting it. Only difference maybe I have the touch bar enabled for auto cad on my laptop. Here is a screen cap of my cui. I really don't understand it but can modify if anyone has suggestions.
0 Me gusta
ireneAZESA
Just discovered it works with my right shift but not my left shift key LOL. I have checked and my shift keys work normally with other programs.
No aplicable
Ha go figure! That is a bit bizarre, though. Glad you got it figured out.
0 Me gusta
