3DOrbit error: "unknown command"
No aplicable
Hi group,
I recently installed Autocad 2014 on a macbook pro (XS Yosemite).
After a few days it started repeatedly crashing, following which I installed the Mac Service Pac upgrades (1, 2 and 3).
It has since been working fine exept for 1 thing:
when I try to 3D Orbit it comes up with "Unknown command "3DORBITTRANSPARENT"".
This means in 3D I am stuck on the fixed views (SE,SW,NW,NE)....
Does anyone know how to repair this?
Best,
Michael
0 Me gusta
Responder
1.347 Vistas
7 Respuestas
Respuestas (7)
maxim_k
Welcome to Autodesk Forums!
Hi Michael,
How do you call 3DORBIT command?
Status Bar, Context menu or....?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Hi Maxim,
Well basically when I go to a 3D view and then hold down shift and drag at the same time the view does not move. A small box next to the cursor flashes up saying:   unknown command "3DORBITTRANSPARENT". Press F1 for help.
The same error occurs when I go via the menu to Orbit: View - Orbit - Free Orbit
As soon as I click 'Free Orbit', up flashes the following box next to the cursor:    unknown command "3DFORBIT". Press F1 for help.
Constrained orbit works without a problem though...
Best,
Michael
0 Me gusta
maxim_k
Have you tried to reset AutoCAD?
You can do this via AutoCAD preferences - Application tab, but keep in mind that you will loose your customizations.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Yep, I reset it but the same problem still occurs...
Any other ideas what it could be??
0 Me gusta
maxim_k
Can you still use 3DORBIT command if you type it from keyboard.
An alias defined for this command in acad.pgp is 3DO by default.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
Nope still the same, if I type in 3DO or 3DORBIT it still comes up with the same message box: "unkown command 3D0. Please press F1 for help"
0 Me gusta
maxim_k
Have you tried to remove AutoCAD, than install it without updates, than test 3DORBIT command.
Than install Update 1, test command again.
Than Update 2, test.
Etc.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
