3d object drawing views on Autocad 2015
No aplicable
There is no tutorial showing how to create the drawings or where the tools are on the mac version! I need to create 2D views of a 3D object and i can't seem to find how...
0 Me gusta
Responder
Soluciones aceptadas (1)
3.515 Vistas
3 Respuestas
Respuestas (3)
maxim_k
Welcome to Autodesk Forums!
Do you mean VIEWBASE command? If so - than it is not available in AutoCAD for Mac.
Do you need real flat 2D objects from 3D objects? - Than use FLATSHOT command.
You can also use SECTIONPLANE command to create Section object, than create 2D section using this Section object.
You can also use old SOLVIEW and SOLDRAW commands to create 2D objects from 3D geometry inside viewports in layout.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
No aplicable
hi, thanks for the quick answer! I've been trying to use the commands you suggested but i dont seem to get the result... (maybe its because im not so familiarized with the program).
Is there a video tutorial that you know of that could help me?
Im attaching a picture of what i need to get...
Thanks so much for the help!
-C.
0 Me gusta
maxim_k
Solución aceptada
There are a lot of video tutorials about creating 2D views from 3D model in AutoCAD with SOLVIEW and SOLDRAW commands:
https://www.google.ru/search?newwindow=1&tbm=vid&q=solview+and+soldraw+tutorial&ei=0U94VdGmJoSTyQPer...
Although they are about AutoCAD for Windows, but in AutoCAD for Mac these commands works the same way.
Here are the links to the help topics about this commands:
SOLVIEW:
http://docs.autodesk.com/ACDMAC/2013/ENU/filesACRMac/GUID-08FE95F0-B91A-424A-B19F-821D5100CCB9.htm
SOLDRAW:
http://docs.autodesk.com/ACDMAC/2013/ENU/filesACRMac/GUID-C2D29999-EB0D-44E3-9107-2365666F120F.htm
Plus - SOLPROF command:
http://docs.autodesk.com/ACDMAC/2013/ENU/filesACRMac/GUID-080247BF-BDAB-49F6-A0A5-966412CEDCE9.htm#W...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
0 Me gusta
