Standard Controls Throughout
Probably due to it's evolution, some of the dialog boxes (ok, a lot) have various controls that are not Windows compliant.  For example, in the "Create/Edit Wire tpe" dialog, the grid control SHOULD sort by single clicking on a column header, like most things do.  Instead, the user has to double click it.  And that isn't documented anywhere that I know of.
Also, when exporting to a spreadsheet, some of the fields have information stripped due to (I suspect) non-standard text fields.  Quotation marks in particular can disappear, and the underscore code (%%U) does as well.  These can also get stripped when updating between related symbols.  Very frustrating.
Other codes (%%D, %%C) seem to be unaffected.
(This is true of ACE2013, don't know about later versions but I bet it hasn't changed.)
2 Comments
t_chaws
Status changed to: Under Review
Thank you for your idea!
We have included your idea in our research bucket and will be looking into it for our future releases!
Keep posting new ideas!
Best Regards,
AutoCAD Electrical Team
