cancelar
Mostrando los resultados de
Quiere decir:
Object Snap Zoom Box
I currently work for a windows company (large see-thru glass objects, not a Microsoft venture), drawing lots of large rectangles (for the most part), so the majority of what I draw are large visual area objects (several to many feet in size), but the framing is only 2", and the details on the framing only fractions of an inch.  So my thought, to save constantly zooming in and out at every intersecting point of the frame, to insure I'm snapping to the correct point instead of the point 1/4" away from it, is to show a zoomed pop-up box in one corner of the screen, let's say approximately 2"x2" or whatever (also depending on monitor size, obviously) that shows which snap point is being highlighted for selection.  And as I move the mouse pointer, it would act just as if I had zoomed in, and would subsequently move to highlight the next snap point.  The box would then disappear once the need to show a snap point was no longer required.  Kind of like having a model viewport whose visual content showed a 1"x1" box around the crosshair.
4 Comentarios
testsubject
This is the AutoCAD Electrical forum.
You will have a better chance if you post this on the AutoCAD forum instead.
MarkFitz
Thanks, I wasn't given that as an option though...
MarkFitz
I was told to go to the "Ideas" "Product Boards", and regular old AutoCAD isn't shown there.  I've used ACAD Electrical before, so that's why I chose this board.  Can you point me in the right direction to get to the main ACAD board if possible?  Thanks,
MarkF
testsubject
Sorry that I cannot help you here. It is strange that there not an idea board for Vanilla AutoCAD.
Enviar idea
