As we all know this forum is used to vent our anger without actually doing anything to solve the myriad problems that ACADE has in the product
With that in mind lets add some more functionality that
- Won’t work properly
- Give you the excuse to say we have listened and produced an answer
So, what the main complaint about the parts data supplied with ACADE
- Its incomplete
- Its missing new items
- Its technically wrong
- You have parts that are not available in my country
Pick any of the above
Now a certain product that we all know makes ACADE look like parchment and a feather pen for technical abilities
Uses SQL to create parts data packages to download
So, if you could read that SQL you could create an extensive part entry
With things like
Connection point cross-section /Weight/Current/Max. power dissipation/Schematic macro/Mounting clearance Width: Left/Mounting clearance Width: Right/Mounting clearance Height: Above/Mounting clearance Height: Below/Mounting clearance Depth: Front/Mounting clearance Depth: Rear/Schematic macro: IEC/Schematic macro: NFPA mm/Schematic macro: NFPA inch/Schematic macro: GB/CCC/Schematic macro: GOST/Connection point pattern
this is a few of the 200+ data entry points in the parts entry
also, in the package is
Electrical schematic drawing
2d Mechanical drawing
3d Model
CNC cutting details
This would make you all heroes and push responsibility for the data consistency out of your hands and add a million plus useful and correct parts to ACADE
