This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Component Orientation
It would be good to have a button on the ribbon/toolbars or a command that causes ACADE to swap blocks out for their alternate orientation. Possibly under Scoot or Insert Component.
Basically, if you have a horizontal CB block inserted, running the command and then selecting the block would grab the block name, find the alternate orientation block and then do a quick swap block to change them. Then allowing the user to select the next block until they hit Enter or Esc to finish.
Regards Brad
2 Comments
artem.jkl
I want to add that very little attention has been paid to the blocks and they are very inconvenient.
What prevents us from reserving some names of view parameters (for example, 0, 90, 180, 270 degrees) and making it possible to implement several of its variations in one block.
Take a look at the C-type relay contact blocks. They are awful. Trying to create your own personal block is useless. Wire connection points are fixed, it is impossible to add legacy block parameters, such as stretching (for example, for the same C-type contacts, to bring the third contact to a convenient place)
https://youtu.be/GjZpKOyEAX4?t=227 - for example, as implemented in another program (I hasten to notice that this is done extremely inconveniently, and in general, work with blocks is inconveniently implemented in that program)
james_moore
I'd like to have this feature for simple default attribute placement and orientation.
As to the comment about making what would be dynamic blocks for symbols, realize the way the program handles blocks and orientation was defined in 1997 or earlier, based on the options available in ACAD at the time.  Creating personal blocks is useless is a bit of an exaggeration IMHO.  Wire connection points are fixed based on the geometry of the blocks.  I recommend you explore the BEDIT command further, and use the Block Swap tool to apply changes to block definitions.  Between those tools and the RENAME command, you should be able to create custom blocks that serve your needs, maybe not 100% of the time, but pretty close.  BEDIT will enable you to add some custom dynamic features to existing inserts.  Also check out the Add Attribute tool, maybe in some cases you would want to build a block without certain attributes and add them where you want to after the insert.  That tool could help you do that.
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
