AutoCAD Electrical Forum
Terminal Stripe Editor
1 REPLY 1
263 Views, 1 Reply
AutoCAD Electrical 2016
I am trying to create a Graphical Terminal Strip using the Terminal Strip Editor. Have about a 128 terminals that are all assigned to the TS1 terminal strip. The problem is the TSE will only list 68 terminals as being on that strip. Why will it not recognize all 128?
Thank You
1 REPLY 1
ccad2509
of the top of my head as i dont have acade on this pc im on check to see all terminals have a tb no in them (unlick all the other ecad systems acade doenot assume the terminal to the right(iec install) is in the same terminal block as the far left terminal and hence you dont need to actually put a terminal block no in it ) are you using installation location codes "=" "+" maybe there sitting in another group
”Boost
