AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Zipping a project with wdp file to keep project structure
9 REPLIES 9
Message 1 of 10
AutoCAD_Oozer
1287 Views, 9 Replies
Hi, I want to zip my project, send it to customer in cad and be done with it. However when I zip, I only have the drawings in there. How can I send it to where when the customer unzips it, he does not have to rebuild it.
What I mean by that is, the order of drawings in my original project list, the subfolders, subfolder names, etc.
Is this something that can be done?
9 REPLIES 9
Message 2 of 10
TRLitsey
in reply to: AutoCAD_Oozer
Hi there,
I did this some years ago.  If I remember right I had a top folder. Under that folder was the schematic folder which contained the schematic drawings and all of the ACE Project support files.  Another folder under the top folder was the panel layout/assembly with BOM and panel modification drawings.  I don't exactly remember but I think I was using WinRAR to zip the files.  When I did the zip, I only had to select the top folder and there was a selection in the zip features to "maintain file structure".  It would unzip in the same file tree structure it had been originally on my workstation.  Once it is unzipped the project could be opened like any other project.  I believe this worked only because I did not hear any complaints from the customer or gripes from my boss.
Good luck
Please mark as a solution if this works for you, kudos are always welcome
Message 3 of 10
AutoCAD_Oozer
in reply to: TRLitsey
This was zipped using "zip" from project tab?
Message 4 of 10
TRLitsey
WinRAR is an application like WinZip.  I think you can find a free or trial version at CNET.com.  Once it is installed you fire up the application and select the files/folders you want to put in an archive (zip) file just like you would in Windows Explorer.  Give the archive file a name, click on the button to start and it crunch away.
Good luck
Message 5 of 10
AutoCAD_Oozer
I've got WinRAR set as the zip tool in the wd.env file
Project w SubfoldersProject w Subfolders
So if I zip from the Project Tab
Zipping ProjectZipping Project
I get the zipped project just fine and I have the drawings in the archive
Zipped ProjectZipped ProjectArchived DrawingsArchived Drawings
If I zip this outside of ACADe I can keep the wdp file and anyone can recreate the project, but I usually get (for larger projects) projects that have to be shared through apps like Dropbox because they get so large.
I would like to use the ACADe zip function because it only archives the necessary files, drawings and AEPX (I don't know what aepx does) and I feel that this would create a less complicated file to share.
So when zipped using the ACADe Zip function, is it supposed to include the wdp file?
Message 6 of 10
rhesusminus
Yes. The WDP file is supposed to be there.
Have a look at these instructions, and see if you can make them work:
https://forums.autodesk.com/t5/autocad-electrical-forum/how-to-add-7-zip-to-the-wd-env-file/m-p/7339...
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. :winking_face:
Message 7 of 10
darok8
in reply to: rhesusminus
Could you check the link, because it doesn't direct to where it is?
Message 8 of 10
rhesusminus
Feel free to say "thank you" to Autodesk. In their wisdom they've deleted all posts older than 10 years.
Trond Hasse Lie
Ctrl Alt El
Message 9 of 10
darok8
You mean you need to make a backup of your project in .ZIP, and send it to the client, but keep the folder structure, "Power", "Control", "Communications" etc.. as you have it in the AutoCAD Electrical environment, I would take two paths;
1.- Export in PDF and select "Include Bookmarks", that will keep the structure you generated, but it will only be in PDF.
2.- Export in .ZIP from AutoCAD Electrical and when you open it it should have the same structure that you generated in your project, well I did this in AutoCAD Electrical 2023 and it has worked for me.
Message 10 of 10
darok8
It's good to know what you're saying, because I found what I was looking for on YouTube. Here's the link.
https://www.youtube.com/watch?v=C9qIxz5u3bs
