Hello, Please if someone can help on this. when I use source and destination the size of the XREF comes in different between? XREF of source Width Factor 1, and XREF Destination Width Factor is 0.8. Knowing that on my DWGs of both are set to 0.8. Thank you.
In the block editor, the width factor is 0.8 for the definition:
So, something goes wrong before AutoCAD Electrical tries to do something with the block.
Are you sure you're getting the correct block when inserting the signal in a new drawing?
Thank you. I forgot to uncheck it the first time. But, is there a way to find out why is it coming with Width factor of 1 instead of 0.8?
