suleiman helweh
It appears you have placed wire arrows on the first sheet from wires 1,2,3,4.
I do not see destination arrows on the second sheet.
When you have a wire placed on the drawing, you need to use the "Wire Numbers"
tool or
the "Edit Wire Number"
tool to attach a wire number to the placed wire.
Once you have the Wire Number associated, use "Source Arrow"
tool. Select this tool, then the wire you want to have shown elsewhere on in your project.
You should see this menu:
From here you can enter a code that needs to be unique. Example "1L2 TO RUNG 141"
Then hit the "OK" Button.
You will then see this menu:
Select "OK" if the second location for this same wire (same wire number) is on the current sheet. Otherwise select "NO". (In your case it seems you want the wires to start from sheet 1 and go to sheet 2, so you would select "NO" here.)
On the second sheet, select the "Destination Arrow"
tool.
Now select the wire you want to have the same wire number from the first sheet.
You will now see this menu:
Type in the code you entered in for the source arrow from the first sheet.
*Hint: If you recently entered the source code, select the "Recent" Button instead!
Now select the "OK" Button, and the arrows should now be completed.
Be sure to check the first sheet to be sure the source arrow states the rung it is sending to. If not you may to to right click the source arrow and select "Retag/Update"
