AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Wire sequence batch rebuild
4 REPLIES 4
richter
331 Views, 4 Replies
Hello guys,
is there a way to rebuild all wire sequences according to Project Settings without using Edit Wire Sequence on all networks? We need to rebuild whole project according to Left to Right setting in Project Settings.
Thank you for any help!
Martin Richter
Tags (1)
4 REPLIES 4
rhesusminus
in reply to: richter
Hi Martin.
If you've set that order in the project settings, just make sure you're not overriding that setting in any of the drawing properties:
Do you have a lot of edited wire sequences in your project that you want to remove?
Running a AEREBUILDDB command and checking the "Include wire connection processing" should rebuild the project database's wiring order.
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
richter
in reply to: rhesusminus
Hi Trond!
Thank you for the answer. Actually I tried your workflow, I set Drawing Properties to No Override, applied project defaults to drawing (Left to Right), rebuilt the database, but the wires are still going the wrong way. What I need to remake is, that every wire in the project / drawing goes in the order from left to right. After the steps I mentioned I still get following order:
Do you have any idea how to do it for the whole drawing / project?
Thank you!
rhesusminus
It says "left to right, moving down", so what you see here is correct. The connection point on the right is higher (have a great Y value) than the connection point on the left. Do, the connection will start there.
Trond Hasse Lie
Ctrl Alt El
richter
Thanks, your answer cleared it for me. I set the project settings to Top to bottom, moving right and after database rebuild it is ok.
Have a nice weekend!
”Boost
