Where to find (multiple) socket outlet, socket outlet with protective contact and 2 way single pole switch symbols in the IEC library
musulinUCQM4
musulinUCQM4
In Auto Cad Electrical I am trying to do an electrical house wiring project.
I have selected IEC 60617 library.
Where can I find, for example,
  • socket outlet,
  • multiple socket outlet,
  • socket outlet with protective contact and
  • 2 way single pole switch symbols
The symbols are available in IEC 60617 standard (PDF file link)
Thanks.
rhesusminus
AutoCAD Electrical is for panel builders etc., so you won't find these symbols.
Look at AutoCAD MEP or Revit MEP for electrical house projects. They would have the symbols you need.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
jjohnston2FBYC
The golden rule is, if you can't Find them Make them.
Sorry, I don't use IEC so unfortunately I can't help much.
