Hello everyone. I am a student of electrical engineering. I'm used to using the ordinary AutoCAD for my works. Please I want to know the advantages the AutoCAD electrical has over the ordinary AutoCAD software.
Hi Adepatewaliu,
There are many advantages to using AutoCAD Electrical vs Regular AutoCAD, but it depends on how you plan to use the software.
If you are making Electrical Scematics, one line diagrams, and Panel layouts then AutoCAD Electrical is the best way to go.
If you are making circuit boards well its not the best but if you only doing one or two layer CB's it might be ok, if its a 50 layer CB with crossing paths and links all over for multiple transistors...probably not the best.
If you doing housing Electrical work ( or commerical buildings) Then MEP and evit would be a better choice..but I'll leave that one for now.
lets take a look at some advantages:
Hi Adepatewaliu,
If you doing housing Electrical work ( or commerical buildings) Then MEP and Revit would be a better choice..but I'll leave that one for now.
I Love when the system gets screwed up then double posts...LOL
Hi ,
My name is Hans.
I am a junior electrical engineer.
I am new to autocad,
My question is : is it possible to make a single line mechanical design and implement electrical drawings on it with autocad electrical ?
I have downloaded autocad electrical software but I feel like I should have downloaded autocad
