WD_JUMPER syntax change
shuhn
shuhn
Has anyone else noticed there seems to have been a change in the syntax for this attribute?  I have some power supply symbols in my library, where we built-in the attribute so we wouldn't have to think about it.  I'm on 2023 now and this didn't appear to be working.  I reinserted/updated blocks, reconnected wires, and the whole shebang.  When I found something about the "Internal Jumper" command, I tried that and it actually showed my jumpers in the dialog box.   Well, I added the connections again through the command prompts, and I noticed the difference.
Previously, the attribute value for jumping terminals 5 and 6 together and 7 and 8 together was ((05 06)(07 08)).
After going through the command prompts to add the connections, the attribute value is  (("05" "06")("07" "08")).
I don't see anything on the message boards about this, so I assume people don't use this feature very often, and it actually shows my old syntax in the help files, so maybe AutoDesk is not aware of this?
alds02
For what it's worth, I do use WD_JUMPER, and I see each syntax example present in different symbols.
There's a parametric connector, for which I used the Internal Jumpers dialog box. That one has the "" around the pins.
Then there's a custom pneumatic Y symbol, and that does NOT have the "". I don't distinctly recall but assume I made that symbol with WD_JUMPERS set from the beginning. But I'm not using wire numbers on pneumatic tubing, so I just added one to see if WD_JUMPERS is working. It does appear to be - I added a wire number to one branch, then used Edit Wire Number on the other branches and it pulls up the number from the first branch.
This is confusing.
