Announcements
Wanted electrical symbols
I don't have autocad electrical software only autocad civil 3d and after searching the web I was unable to find some stand electrical receptacles.
What I am look for are blocks drawn to a 1:1 scale for a single, double, and quad receptacles
If someone has some with the standard electrical symbols I really would appreciate it.
rhesusminus
Are you looking for the SCHEMATIC representation or the "this is what it look like in real life"-version?
For the"real life" one, contact your breceotacle supplier.
For schematic, create yourself. Two lines and an arc.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
I am looking for the schematic to be used in my floor plan design. Wound you have some already made as a block drawn to a 1:1? I thought receptacle symbols are two lines and a circle?
rhesusminus
You are probably looking for AutoCAD MEP and not AutoCAD Electrical. In Electrical there is no "scale" for schematic symbols.
Trond Hasse Lie
Ctrl Alt El
Thanks for your help.
Johneng
Find attached standard NEC symbols. Receptacles are located on the top row second panel from the right. Scale to suit your needs.
