Vault & Equivalence Value (CAT-MFG-ASSYCODE)
jimm_motyka_777
jimm_motyka_777
As our Vault Admin, I am somewhat green with ACE (yet coming up to speed quickly).  Hopefully others have seen and working through this situation before.
When this message pops up, what issue or area am I'm chasing to sync this between ACE and Vault?
Any help or direction would be greatly appreciated.  Thank you!
jaya_priya_ramasamy
Hi @jimm_motyka_777
When you are checking in your Electrical project to Vault that supports CAT-only key system, this warning message appears.
If you check into to CAT-MFG-ASSYCODE Key System vault, this warning message will not appear.
Please go thru the below help page and some more relevant documents to understand more.
AutoCAD Electrical 2025 Help | About CAT-MFG-ASSYCODE Key System | Autodesk
AutoCAD Electrical 2025 Help | To Work with CAT-MFG-ASSYCODE Key System | Autodesk
How to integrate AutoCAD Electrical with Vault Professional (autodesk.com)
Jaya Priya Ramasamy
Senior QA Analyst
www.autodesk.com
jimm_motyka_777
Thanks for the follow up.  After scouting around, I did find the info that you directed me to.  I confirmed the settings with a current user.  My recommendation is going to be to purchase a SQL server in the next budget.
Thank you again for your info.  I can always rely on the Forums to lead me in the proper direction.
loturner
why would I use the new format?
