Using two AutoCAD's with one application
Bh_GuruCharan
Bh_GuruCharan
I have downloaded AUTOCAD but now I need AUTOCAD Electrical too so is there any way of downloading of only Electrical Toolset like library file of the AUTOCAD Electrical so that It would save some space
pendean
Community Legend
Community Legend
AutoCADELECTRICAL is a separate software installation, and you'll use that newly installed software when you need to use the ELECGRICAL tools and libraries.
Same applies to the other variants they call "toolsets": ARCHITECTURE, MEP, MAP, MECHANICAL, and PLANT3D.
The only "toolset" that is a pure add-on is RASTERDESIGN.
Nope, there is no other way. It's 2024, HD capacity should never be a concern today if you purchased your unit for long term value and use, not shortterm savings.
HTH
