I have been trying to use the MDI to view more than one drawing with a view to dragging and dropping, or cutting and pasting items between drawings.
I fell at the first hurdle.
If I open 2 drawings from a project, and (I have to manually) arrange them side by side, I can't simply click in the drawing I want to focus on as the start page keep coming to the front, window keeps disappearing, and I get other strange effects.
There doesn't seem to be any sensible autoarrange, or means of tiling vertically or horizontally either
Is this functionality not supported, or is there a setting I need to change?
I'm using a windows7 64bit machine if that's relevant.
There is a Multi-document interface? You can tile the window and make it smaller to see them side by side if you wish:
I generally simply hit CTRL+TAB to cycle left to right through tabs, or CTRL+SHIFT+TAB to go right to left.
