When I try and update the WD_M block using the 'Update to new WD_M Block, Values and Layers' command, I get the following error in the command window:
Command:
PANEL:
Type "swap_pnlm" to swap and conv to new lays carried on new wd_pnlm.dwg
Type "swap_pnlm_keep" to swap but keep drawing's existing layer names
SCHEMATICS:
Type "swap_wdm" to swap and conv to new lays carried on new wdm.dwg
Type "swap_wdm_keep" to swap but keep drawing's existing layer namesBlock WD_M references itself
*Invalid*
I'm not sure how this block can reference itself??!!??!! I am using ACADE 2014 and as far as I can remember it worked in previous versions. Could it be a setup issue?
Solved by rhesusminus. Go to Solution.
I would take a look at the WD_M.DWG-block in your symbol library.
Seems like it contains a block named WD_M.
Make sure all objects in this file is "exploded", and use the PURGE command to remove all blocks.
Try again.
