I am trying to use Utilities to update the WD text style project wide.
After selecting "Utilities", I select the "Change Style" checkbox under the "Change Attributes" section. Then I select "Setup". From this next menu, I select the Font I want and then "OK". I select "Project" and "OK" on the next screen, and have every drawing processed.
Once the process is completed, I see that a text style "WD_IEC" is created and set as the font I previously selected.
I want this to work for the "WD" text style, NOT "WD_IEC".
The Acade Help Menu states: "AutoCAD Electrical toolset processes the selected drawings and adjusts the text style WD or WD_IEC to the specified font name."
How do I make the "OR" mean "WD".
