Unable to place parts
friedl.basson
friedl.basson
Hi -
I am unable to place a Particle Boron part on the custom PCB.  I am familiar with Eagle in terms of error messages you receive when exceeding allowed board space, but in this case, a semi-circular green shape appears when trying to move the part onto the board.
The board was created by projecting from a sketch in fusion in order to fit the enclosure.  Is this due to board size restrictions?  Find some screen grabs attached.
Would appreciate your help.
Many thanks. Friedl.
rhesusminus
You should probably ask this question in the Eagle-forums.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
friedl.basson
Hi @rhesusminus -
Thank you for the reply.
Why Eagle, this is and Autodesk Electrical 'problem' ??  In Eagle this works just fine, so I have reverted back to using Eagle in the meantime.  I would still like to know whether it is due to the board size restriction or whether it is simply me doing something wrong 🙂
Many Thanks!
Friedl.
rhesusminus
No. This isn't AutoCAD Electrical. Fusion and Eagle are something completely else.
We don't do PCB's in AutoCAD Electrical.
Trond Hasse Lie
Ctrl Alt El
friedl.basson
Hi -
My apologies.
Regards, Friedl.
jseefdrumr
EDIT: whoops, didn't realize I repeated another answer
Jim Seefeldt
Electrical Engineering Technician
