Announcements
Transmitter Symbols
Arlene_Brown
Transmitter Symbols
Arlene_Brown
Hi there,
Can someone please advise if there are Temperature and Pressure transmitter symbols available in the AutoCAD Electrical libraries?
Thanks in advance.
Regards
Replies (7)
rhesusminus
Only these standard ones:
AutoCAD Electrical 2024 Help | JIC Symbol Preview - Pressure and Temperature Switches | Autodesk
AutoCAD Electrical 2024 Help | IEC-60617 Symbol Preview - Pressure and Temperature Switches | Autode...
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Arlene_Brown
Thanks for your reply.
These are switches. Is there Transmitter symbols, ie 4-20mA output?
rhesusminus
For IEC standard, we use a rectangle with some connection points, custom made. The tag displays what kind of transmitter it is, so that we can use the same symbol for different transmitters.
Not sure how this is done with JIC/NFPA.
Maybe @dougmcalexander can share some knowledge about this?
Trond Hasse Lie
Ctrl Alt El
Arlene_Brown
Yeah that's what I use at the moment. However I was just wondering if there was an proper transmitter symbol that I could be using.
Thanks you for your replies.
dougmcalexander
There are specific temperature and pressure switch symbols in the NFPA library.  They are derived from ANSI Y32.2.  I will post a screenshot from the NFPA library menu.  These are switches.  For RTD, pressure sensor, and load cell, a derivative of a resistor symbol is often used.  The tag letters denote the exact component class, similar to what Trond described for the IEC.  There is a specific symbol for a thermocouple in the Instrumentation category of the NFPA menu.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor
Specializing in AutoCAD Electrical Implementation Support
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
ccad2509
are yu tryng to draw instrument loops  if so they should look something like these
Arlene_Brown
I am trying to improve the representation of my standard Junction Box Wiring Diagrams and make them more smart. I was wondering if there were ACADE Instrumentation symbols available for Pressure & Diff. Pressure Transmitters, RTD's &  Temp Transmitters etc.  I currently have custom symbols which are just blocks with terminals. However I now believe that these are not available and that I need to use custom symbols. I have used lines instead of wires in my Junction box Wiring Diagrams. Does anyone have any examples of a Smart Junction Box Wiring Diagrams? The Instruments, Junction Box and Linked Tag numbers on my drawings are currently the only current smart features.
Thanks in advance.
