Title block Update
Title block Update
gcsjlewis
Title block Update
gcsjlewis
Using AutoCAD Electrical 2025, I cannot seem to find how to change the location of the default.wdu.  I would like this to be stored on our network, but its defaulting to the c:/users/username/appdata/roamiing/autodesk/autocad electrical 2025/r25.0/enu/support/user/ folder.
Is there a global variable i can set in the wd.env file or any ideas?
I have a screen shot saved on our network of what it should look like, but our other drafter forgot to "check" all the boxes after installing, and was sending drawings out with all the fields not being updated.
I would like to think if it is in the same location as the default.wda, default.wdt files are (which are on our network), it would be look there, but not the case with the .wdu file.
rhesusminus
I believe this file is hardcoded to be saved to the user folder.
You can change the USER-folder to point to a networked location, but you REALLY shouldn't share the user folder on a network.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
