Text size different when plot
I´m having a issue to plot some schematics. The files shows the problem.
1 - As text show in PDF format
2 - As I see the model
This happen also in Arrow Sources/Destinations and this case is a attribute of connector.
TRLitsey
Hi there,
It sounds like another font substitution issue.  I would suggest you run a search on this board for ...
Font Substitution
or
Font Substitution PDF
Good luck
Please mark as a solution if this works for you, kudos are always welcome
