Terminals, electromechanical project
svetlanae
svetlanae
When designing in AutoCAD Electrical, each terminal is displayed separately in the location tab and is characterized by the following attributes:
Terminal strip name, for example XT01
Terminal number (wire), for example 1
Level (L1, L2, L3 ...)
in the connection tab in the component column is the name of the terminal block
In the Contact column, the combined parameters (terminal number: terminal connection is external (E) or internal (I)). Example 1: I
There was a question - how to communicate with Inventor, if the Inventor component has a designed terminal and, accordingly, the electrical contact for this part has a permanent contact parameter designation, for example, 1: I, and the dynamically changing designation of terminal contact parameters is transmitted from AutoCAD Electrical.E1.jpg
Replies (0)
