I'm building a simple circuit - a transformer feeds terminals that are jumpered together, distributing power to various circuit breakers and fuses. The terminals are single level screw terminals that may have up to two wires per terminal.
I've tried this two ways and neither do what I'm looking for.
With X1 I put terminal symbols on every branch. Despite the jumper i still see connections in the terminal strip editor between X1 terminals as if there is an actual jumper wire between them consuming one of the two screw connections.
With X4 I put a single terminal symbol, hoping that AutoCAD Electrical would see all the branches below. It did not.
The drawing:
X1 Connections:
X4 Connections:
How do I accomplish this without consuming my terminal connections with the jumper?
