Terminal Strips entering horizontally
How can you insert the terminal strip horizontally rather than vertically from the editor?  If I do simply rotate after entering, every time I rebuild it, it goes back to vertical.
rhesusminus
In the terminal strip editor, set the rotation to 90 before you insert/rebuild the terminal strip.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
