Terminal Editor Wizard stopped working.
capplegate7CEK3
capplegate7CEK3
I have a project where the Termilan Editor no longer will show.
I started a new blank project, Created a new page, drew a new bus of 3 wires, Added three terminals, and in this project the Editor pops up.
I have deleted every instance of any known terminals in my project,
I tried to Run:
Purge document
AEREBUILDDB
With no change. I added a new terminal, and the wizard still does not appear.
rhesusminus
You've done everything correct so far. I guess we'd have to get the actual project files to debug this.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
JeffatPrimex
Not sure if this would help but,
Have you tried ATTDISP on?
I've seen ACE leave wire numbers hidden in drawings.
Best regards,
J.
arshdeepsingh404
Hello @capplegate7CEK3
Sometimes deleting the project database to force a manual re-creation does the trick. Check out the attached document.
Arshdeep Singh, C.Tech, CMSE®
Electrical Designer & Programmer
Please mark as [Accept Solution] if this resolved your issue. It might help someone else with the same question. Likes are welcome!
capplegate7CEK3
Thanks for your insights so far. Obviously the AEREBUILDDB part of the document I have done. I did try to delete the *.mdb with no luck either.
When I run the command, this is what I get in the console.
@rhesusminus I'll try to DM you a copy of the file. Thanks
capplegate7CEK3
I started a new project and found the offending file. There were cable markers with question marks next to them. I deleted those components and the issue went away.
rhesusminus
Glad you figured it out. You should never use any special characters with Arcade. Most of the program is programmed in AutoLisp, a programming language from the 1950's, and it doesn't handle special characters very well.
Try to use a ", %, $, ?, & or * somewhere for example, and you WILL break functionality. And yes, Autodesk is fully aware of this, but it would just cost too much to fix this.
They've purged posts older than 10 years from these forums, so we can't find the history of this any longer.
And this is yet another reason to why I stopped working with AutoCAD Electrical.
Trond Hasse Lie
Ctrl Alt El
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
