Terminal block with TERM01 not working correctly.
I am having problems with one block. This is a terminal block and all four sides are named X1TERM01, X2TER01, X4TERM01 and X8TERM01. I normally put a wire number on one side and it carries it to the other sides but for this block that is not working. I was hoping you guys could give it a look and see if you find something wrong with it and make it work correctly.
Please let me know what you can find.
jseefdrumr
The issue isn't with your XTERM attributes, it's with the name of the block itself. From ACADE Help:
Standalone Terminal Symbols
Stand-alone terminals follow this naming convention:
  • The first two characters are "HT."
  • The third character is "0" if the wire number does not change through the terminal, "1" if the terminal symbol should trigger a wire number change.
This is one of the ways in which terminals are different from other symbols in ACADE.
Hope this helps,
Jim
Jim Seefeldt
Electrical Engineering Technician
Thanks. That helped a lot!
