Terminal block with different wire number
pajder
Message 1 of 9
pajder
Hi everybody,
I have an issue with ACADE in case where I use terminal block and I want to have wires with different wire numbers from each side in case when one side is connected to destination arrow. Problem is that wire connected to destination arrow inherits wire number from source side, which is fine, but at the same time ACADE doesn't allow me to change other wire (connected to the other side of TB). Is there any solution how to overcome this issue?
For better understanding please take a look on attached snapshot.
Replies (8)
Message 2 of 9
JeffatPrimex
Sounds like you want to use an HT1001 terminal block instead of an HT0W1 terminal block.
Best regards,
Jeff
Message 3 of 9
pajder
Thanks for your reply, but unfortunately that is not solving my problem. I tried that already and ACADE doesn't allow me to change wire number. I can change it if I disconnect from source arrow but when I re-connect wire to arrow then I can't change that number to match with source wire.
Is there any other solution for this?
Thanks in advance
Message 4 of 9
JeffatPrimex
Looking at your image I see a destination arrow on a dashed wire to a terminal block. If you change the terminal block to an HT1001 block you should not have any problem using a source arrow and assigning a wire number to the dashed line. If you want to change that dashed line with the destination arrow as shown you need to have a source arrow somewhere with a matching signal code and then assign a wire number to the source wire then do a signal update refresh to see the number appear on the dashed wire.
Best regards,
Jeff
Message 5 of 9
Icemanau
Each terminal style has 4 versions.
Plain - No number or anything - HT0_01
Utilising the WIRE NUMBER - HT0W01
Separate terminal number - HT0001
Separate Terminal Number WITH Wire Number Change - HT1001
To change a wire number going through the terminal you have to use the last version which is what Jeff was trying to say.
The problem comes in when someone wants to change a wire number while going through a terminal which takes on the Wire Number as a means of identification.
You will need to make a copy of the base dwg for HT0W01 and rename it to something like HT1W01_WIRECHANGE. Then you need to edit the base dwg and change the 4 wire connection points and the associated descriptors.
Only change the LAST DIGIT and make sure that each X# has the same last digit.
For example
X1TERM01 -> X1TERM01
X1TERMDESC01 -> X1TERMDESC01
X2TERM01 -> X2TERM02
X2TERMDESC01 -> X2TERMDESC02
X4TERM01 -> X4TERM03
X4TERMDESC01 -> X4TERMDESC03
X8TERM01 -> X8TERM04
X8TERMDESC01 -> X8TERMDESC04
Finally save the block and test it in a new dwg.
Now when you insert this block, it should allow a Wire Number Change and will hopefully use the number from the wire connection on the Right Hand Side.
Regards Brad
Brad Coleman, Electrical Draftsman
Message 6 of 9
pajder
Hi Jeff,
I already have source arrow with proper sign code and assigned wire number, that is automatically inherited on destination arrow and dashed wire (which are on current drawing). I tried with HT1001 but when I try to assign number to the wire on right side of terminal block ACADE doesn't allow me to do it. Also, there is a prompt massage stating that it can be done because of destination arrow. It seems like terminal block transferring wire number from one side to another, which is really weird for HT1001. If I try to trick CAD by disconnecting dashed wire from destination arrow I can assign wire number to the wire on right side of TB, but then my wire number for dashed wire is gone, and I can't do anything, again really weird.
Is there any other solution?
Message 7 of 9
Icemanau
In that case, disconnect the dashed wire from the terminal block instead of the arrow.
Set you wire number on the solid wire then reconnect the dashed wire to the block.
Regards Brad
Message 8 of 9
JeffatPrimex
It sounds like your block is still an HT0W01 block or your HT1001 block is not setup correctly or it's definition has not been updated in the drawing. I just tried your scenario in the demo project using an HT1001 block and it seems to work just fine.
Best regards,
Jeff
Message 9 of 9
ramesh.kambang
  • Try using one of the marked in RED below to see how they behave
  • Try your block on demo project drawing
  • try marked in RED below on the demo project drawing
  • if the marked in RED work and your block still doest work on demo drawing, copy one the marked in REDs, rename as per
      instruction above
     and modify it to suit and try
  • OR post your block and drawing, members can help you.
Ramesh Kambang
Aerospace System/Design Engineer and eVTOL/EWIS Expert
EASA 21J, UK 21J, MAA DAOS, Certification Specification CS23-29, CS-ANCS, CS-STAN and EVTOL
Please select "Accept Solution" if this post answers your question.
